Ah i didnt notice... but you can compare these anyway
Erin draw the line at -3dB, but for example, the 5040 It's 75° at -6dB while the kef is 60 and then 50°
i see the tweeter at -6dB is kind of 40°
Im not sure if only a listening can be the final word about the soundstage in the highs, but being honest i don't think vertical is a problem.... but when im walking i noticed the r7 managed to sound more coherent, but in my chair thats the 100% listening time i noticed no difference vs d'appolito, in fact i noticed better coherency... but thats 3 drivers... not 4 like the typical 3-way
im also thinking in a second hand KEF REERENCE 3, i will won vs my C500's
Better LFE
vertical sweet spot will be wider, but i 100% dont care how it sounds while im walking in the room
Better looking
I will loss:
Spacial effects
Wider soudstage and much more wider highs
I like how the mids to highs sound more in the C500's
I guess the KEF REF3M might sound better in the mids to hf im still lossing the spacial and soundstage thing.
I also like a lot having LFE...
The MA PL200 3G is a strong option, i just think the overall image is worse than the c500's at close distances, i don't think there is much of a difference when you are in the sweet spot (in your chair or whatever) and you are at like 3 meters~ or 2.5m meters ~, but i noticed the HF are a tad bright, while being very good quality, the off-axis dispersion is wide on the PL. What im not sure if the PL200 3G give that subwoofer like LFE, the 300 3G does easily... the LFE is very good on PL300 3G while having that wide highs just a tad brighter than i like, but maybe i can live with that little brightness, is a lean brightness is not a peak or something. If the crossover would have a -1dB switch it would be textbook imho, for my ears.
I think a strong option is the PL200 3G.. with a lot of foam in the vertical sweet spot. Lol. But dont get me wrong, is like 1db? maybe in the listening test you wouldn't even notice... and maybe im too young? idk. But certanly is a good speaker, very pricy too.
Im still not listened the KEF REFERENCE 3 META, but now you like your KEF?
