I purchased quite common surge protector. It has coils with ferrite cores, condensators which do similar kind of filtering, and varistors for the actual surge protection. There is also a claim it filters AC mains noise, but there is another claim they made.
Suppose a device you use dies, and it does it in "fancy" way with fireworks. One of my PC PSUs literally melted and all capacitors inside exploded...
Manufacturer of the surge protection made a claim that surge protector does not protect just from surges and noise from AC mains, but also in case of such catastrophic failure of a device connected to the powerstrip and from noise which might be generated from such device.
Well... since most devices have a ferrite core as a first component in their power supply, is such filter even justifiable in case you suspect your amp, PC or literally anything may generate audible noise and send it out through powercord and powerstrip to other devices?
