My inner monk is triggered by @Purité Audio insisting in using the term SPF (spf record?) instead of SFP..
But... but... did she pass the thigh test?Patricia Barber is literally in my front room if I just stretch out my hand…
I'm sure AI can help with the pictures.Patricia Barber is literally in my front room if I just stretch out my hand…
Sun Protection Factor - The question is, has Keith been out in it too long without enough of it on?My inner monk is triggered by @Purité Audio insisting in using the term SPF (spf record?) instead of SFP..
Well... I was going to suggest that @Purité Audio needed to go for the gusto and perform the Melody Gardot shakedown cruise...I'm sure AI can help with the pictures.![]()
Coincidentally I have been out in the sun and suffered some skin damage which I am treating, so perhaps SPF ( always 50 now) is on my mind.Sun Protection Factor - The question is, has Keith been out in it too long without enough of it on?
Veils must have been lifted to the ceiling on the second floor. Blacks are as black as a black cat in a coal mine at night.I must thank Eddie Hing at Universal Networks, he really de-mystified the whole procedure, looked at the Eversolo spotted they had made a mistake, sent me the correct components and it all works and the noise, the noise you can’t hear or measure has now completely disappeared.
Bituminous or anthracite? These things are important!Veils must have been lifted to the ceiling on the second floor. Blacks are as black as a black cat in a coal mine at night.
Anthracite obviously .Bituminous or anthracite? These things are important!
You know its also that case with LAN dont you?The only truth here is that it does provide electrical isolation
Ok? Doesn't mean the optical connection doesn't.You know its also that case with LAN dont you?
Congratulations, you are a true gentleman.you can literally reach out and touch Patricia Barber’s thigh .
I wasn't aware that you are a particularly new doodadIt’s a new doodad that doesn’t do much but looks attractive, very much like myself.
You perhaps need to increase your ability to detect parody.Congratulations, you are a true gentleman.
Old doodad.I wasn't aware that you are a particularly new doodad![]()
Language allows us to express our thoughts, we just need to know how to use it correctly and politely.You perhaps need to increase your ability to detect parody.
