Purité Audio no longer lacks moral fibre/fiber !
Purité Audio
Industry Insider
Barrowmaster
London
I have an Eversolo T8 digital transport which I use with my superb Sigberg Sarannas ( digital out of the T8 straight into the Sigbergs) the T8 has an SPF optical input,
Now Eversolo wouldn’t include SPF unless it made a huge difference in SQ would they?
So I contacted Eddie Hing at Universal Networks, https://www.universalnetworks.co.uk/
he kindly suggested some suitable components, ( frankly life is too short to wade through optical acronym city )they arrive tomorrow so hold your breath for veils being lifted, blacker blacks, unbridled musicality and cute yellow optical leads rather than that ugly cat 5.
Lol, yes, that very demanding low single-digit Mbps stream at best (lots of content probably would be measured in kbps).
In any case, it's just SFP, not SFP+, so it's full-duplex gigabit same as the RJ45 ethernet connection. The only truth here is that it does provide electrical isolation, but I don't believe noise getting in via the ethernet is an actual problem. Might be nice if you're located more than 100 meters from your switch, I guess.
It’s the ‘noise’ Kyuu you can’t hear it and obviously it can’t be measured but once it is removed you can literally reach out and touch Patricia Barber’s thigh .
Can't argue with that. Certainly can't touch anyone's thigh with dirty old copper connections.
Cary on: just got me some popcorn :)
Pictures of me caressing Pat Barber’s thigh to follow…
Sadly the components wont arrive until Monday so thigh stroking will be postponed for a bit.
Given my level of technical (in) competence I almost certainly won’t get them to work.
Well that was surprisingly uneventful!
I am now an SPF expert any questions done hesitate!
I must thank Eddie Hing at Universal Networks, he really de-mystified the whole procedure, looked at the Eversolo spotted they had made a mistake, sent me the correct components and it all works and the noise, the noise you can’t hear or measure has now completely disappeared.
Patricia Barber is literally in my front room if I just stretch out my hand…
I am rarely coherent.
Just imagine the improvement if I daisy chain four or five of these!
