So, here is a comparison of the measurements from the manufacturer and
@sgoldwin.
This looks quite good. The crossover of the woofer is definitely set up correctly.
The tweeter curve looks a bit strange, but I think
@sgoldwin said somewhere that his measurement microphone is not calibrated, which would explain the strong high frequency sound pressure increase.
According to this data, I would say that almost everything is connected correctly.
Only it should be so that if all chassis are connected with the correct polarity, then the green curve shown in
post#192 should be measured and if the polarity is reversed for one chassis, the brown curve.
It is very important that it is done identically for both speakers so that the speakers do not radiate sound in opposing phase.
