Review and measurements here
https://hificompass.com/en/reviews/purifi-audio-ptt65w04-01a-midwoofer
I find quite interesting that on a "science" forum the only reactions to a surround shape which is obviously the result of computer assisted design are:
Measurements are also provided, on which nobody gives a f..., for the good or for the bad.
You guys are funny sometimes
Looks like they are re-resurrecting the wierd roll surrounds everyone was doing in the 80s for more "linear" excursions. (they all fell to pieces eventually)
Yes, the T34B-4 (or T34A-4) would be a great match.I suppose limiting excursion by placing these drivers in a 3-way (maybe start at 200-220hz or so) might extend the life of the surround if that's a concern. I find most 2-way systems anemic regardless.
I kinda wish it were a 5.5" or 6.0" in that case - it'd help with the tweeter transition as well, as it looks like this driver has a minor hiccup around 1.5 to 1.8Khz, and then becomes less usable past 2Khz WRT both dispersion and distortion. It can be difficult to get a tweeter to play that low w/o straining if you're aiming for high SPL capability and at least somewhat matching the Purifi's distortion.
Edit: Although someone mentioned the Bliesma T34B-4 on the 1st page - plays loud, low, and costs just as much
That said, this driver seems to best the distortion measurements of some of the past top drivers.
That is clever!Woofer and passive radiator are for sale!
https://purifi-audio.com/vare-kategori/transducers/
Rubber surrounds do not suffer the same rotting issues as the old foam ones.
Iv had rotted rubber surrounds on my old vivid b1's.I wish that were true. I had to toss four 30W54s and two 21W54s when their surrounds rotted out.
I could be mistaken, but these definitely look like foam surrounds to me, not rubber:I wish that were true. I had to toss four 30W54s and two 21W54s when their surrounds rotted out.
https://medias.audiofanzine.com/images/normal/dynaudio-30w54-2717669.jpg
On the plus side, foam surrounds are easy to replace:
https://www.speakerrepairshop.nl/en...und-for-dynaudio-30w54-woofer/a-1437-10000020
The ones on mine were definitely butyl rubber.
Rubber surround are not eternal either, but so is the spider (sagging), especially with high compliance woofers.
Let's hope purifi uses better quality rubber then.The ones on mine were definitely butyl rubber.
BTW., regarding that hot discussion about Doppler-distortion and IMD some pages before,
did you notice Purifi has new articles posted on these subjects:
Purifi / tech articles
Yup, its the signal envelope that matters, and long term averaged harmonic measurements won't capture that.
