if going active you can use 3 active woofers and do cardioid etc
The choice active / passive is normally done at the beginning of the design process, not at the end.
I'm one of the few where cardioid isn't beneficial for my use case as I have multiple mlps and sitting down for longer amounts of time is not medically possible.if going active you can use 3 active woofers and do cardioid etc
I think you're more of the norm than people who sit still in a dedicated listening position for hours on end. Maybe not around here, where we have a lot of audiophile (minus the woo, mostly) folks, but certainly in general.I'm one of the few where cardioid isn't beneficial for my use case as I have multiple mlps and sitting down for longer amounts of time is not medically possible.
So, if I understood correclty, You would estimate,that an active approach with this enclosure could not only be realized but might give some advantage to former optimazation?if going active you can use 3 active woofers and do cardioid etc
The voice coil would vaporize if you tried to hit Xmech at 1kHz.[...] force of well over 100lb if it's hitting Xmech at 1Khz+...?
In theory, yes; in reality, rather notThe choice active / passive is normally done at the beginning of the design process, not at the end.
I suspected this didn't actually make sense, but I lack the engineering knowledge to use the power rating (250w) to determine the maximum force we need to worry about for the housing.The voice coil would vaporize if you tried to hit Xmech at 1kHz.
Fun stuff, but I think the overhangs/bridges on the bracing will be too long at full size...?I just did a very rough quick test to see if a one-piece design with internal structure is an option.
It should work.
View attachment 518963View attachment 518964View attachment 518965View attachment 518967View attachment 518968
Are you sure?The choice active / passive is normally done at the beginning of the design process, not at the end.
As a first approximation, you can compute the peak motor force. At 1kHz, the impedance is ~5Ω, so peak current at 250W is sqrt(2×250W/5Ω) = 10A. Bl is 7.7 N/A per the datasheet, so motor force at 10A is 77N or 17.3lbf (7.85kgf). The cabinet isn't infinitely stiff though; any force causes deflection, which means all the heavy bits of the driver need to move some amount in order to apply a force to the cabinet.I lack the engineering knowledge to use the power rating (250w) to determine the maximum force we need to worry about for the housing.
Thanks, super helpful. It seems like the force will be very much more in line with what I expect PLA or PETG to handle. This makes more sense than what I had posted previously. I think PETG is still probably preferable, the forces aren't trivial here, but at least I'm not worried the design needs major modification.As a first approximation, you can compute the peak motor force. At 1kHz, the impedance is ~5Ω, so peak current at 250W is sqrt(2×250W/5Ω) = 10A. Bl is 7.7 N/A per the datasheet, so motor force at 10A is 77N or 17.3lbf (7.85kgf). The cabinet isn't infinitely stiff though; any force causes deflection, which means all the heavy bits of the driver need to move some amount in order to apply a force to the cabinet.
In practice, this is a non-issue. Sound quality would be severely affected way before you'd really need to worry about vibrational forces damaging the cabinet.
I think the cabinet would need to have a compartment added for it, otherwise you're going to throw off the net FR.A plate amp will necessarily remove some of the bracing and foam will it not?
Saves desk space...A couple of power amps on the outside, or a four channel Purifi amp perhaps?
I’ve never seen the need for a plate amp really.
With all due respect, why would you prefer to save desk space vs. The inevitable replacing of a plate amp? What if you can't get the same plate amp or a plate amp with the same dimensions?I think the cabinet would need to have a compartment added for it, otherwise you're going to throw off the net FR.
Saves desk space...
Saves desk space...
They take the decision at the beginning to design a passive speaker and use active crossovers during development for the "lots of benefits" that you didn't care to list. Cool.Are you sure?
I know some extremely prominent and popular speaker designers that design as an active speaker then once the design is locked in, including wave guide and other innumerable variables, then iterate on the passive cross over. This approach offers lots of benefits including but not limited to rapid prototyping.
Your view is very old school.
Theory has a tendency to forget bean counters, marketers and managers. Theory is the only safe space for engineers these days.In theory, yes; in reality, rather not![]()
because the Purifi woofer itself is unbelievably performant (it's basically alien technology)
