wineds
Hi all, I've started preliminary work on the 3D printable version of the cabinet.
Based on a survey someone conducted on Reddit, it looks like the 80th percentile of the 3D printer consumer 'install base' has a print bed size of no more than 220 x 220 x 250mm, so I will be designing for that.
I seem to have been overly optimistic in my initial posts, it looks like it will take at least 8 prints per cabinet at this size. ("at least" because I also think it's important not to have seams cross the woofer or PR cutouts.) I will say people should start printing as soon as they order the kit.
I also would like feedback from the group and/or @Lars Risbo :
It seems pretty feasible to print at a density similar to MDF - someone check my math on this, but a 19x19x19mm cube with heavy settings of 6 walls and 15% gyroid infill has 6859 cubic mm of volume and takes ~5.1g of PLA to print. This apparently yields a density of 737.72 Kg / M^3 which is in the range of MDF.
This would be pretty costly in terms of material (around 11kg for the pair of cabinets, so anywhere from $100-250+ for PLA) and take a long time to print. However, it means no extra step of filling the model with plaster would be needed, at least for the sake of mass / density.
A sturdy-but-light setting of 4 walls and 5% gyroid would take more like 7kg of material for the pair, doable for less than $100, but the density would need to be enhanced with a filler to match MDF. So you'd have to get some plaster, pour it into a space in the wall of the cabinet after assembling it, and hope that step goes well. You can really keep the cost down with plaster as it's very cheap per kilo.
My gut tells me that for a $2200 kit, spending 5-10% on PLA is not a dealbreaker, and simplifying the build process is important. Based on what I've seen so far this is still cheaper than having MDF milled at a shop.
An advantage of designing it with a plaster layer is that it could help with airtightness. Otherwise, you will be relying on glue for that. I am planning on designing a special glue applicator to help with that part, but a solid layer of plaster would be more confidence-inspiring.
I don't think the bracing is a concern with a lighter print, because PLA is stiffer than MDF by quite a bit. I just want to make sure the walls are dense enough so the cabinet behaves as expected in that regard.
Anyone have strong opinions on the above?
(semi-related: anyone know how hot we would expect the crossover parts to get in real use? I'm thinking it would be nice to have a little printable template to attach the crossover parts to, but I lack any and all experience in that domain, and I could imagine PLA failing due to heat in that usage.)
For the money being spent it really should be a PCB for the crossover.
