The waveguide and phase cap/coherer may be different, but the design philosophy is still the same: wide dispersion with constant directivity into the last octave.Not totally correct. Ascilab uses a proprietary waveguide for the Purifi tweeter.
why on earth do you think that? the foam increases the apparent box volume. no change in sensitivity… and I can’t help thinking that the super dense foam essentially filling the space is going to mean a serious power amp.
yes and SB6 crosses much lowerThe waveguide and phase cap/coherer may be different, but the design philosophy is still the same: wide dispersion with constant directivity into the last octave.
My bad. I’m not an engineer. Alas.
sorry for my choice of words.sensitivity is low still good to have plenty of power
Are there any differences between the Valchromat panels?Just to order enough (6) sheets of 19mm Valchromat (500mm x 300mm) for the baffle is going to cost £216.35
Not an inexpensive build.
Total for my Valchromat idea is £390.75.
More than I thought, but not much more. Timber is obscenely priced at the mo’
Another 40 quid for the 12mm birch ply.
Plus the fee for having it all CNC’d.
I may shed a tear or two at the bank.
A whole panel of approximately 3 square meters would only cost €135.
Standard black-dyed 19mm MDF would cost less than €50 per speaker (outer section only) when cut to size.
This is the kind of thing where intuition leads astray; acoustic compliance is what matters (which is a function of the gas law). An empty box behaves adiabatically, whereas a damped box (with carefully chosen amounts and types of foam/stuffing) behaves more isothermally, because the damping material as a heatsink. In other words, the right hand side of the gas equation stays more constant. This reduces the acoustic impedance of the box, which has the same physical effect as a larger (but undamped) box. It also tames the impedance peak of the woofer, which also makes the amp's job easier because it's driving a less reactive load.… and I can’t help thinking that the super dense foam essentially filling the space is going to mean a serious power amp.
How does this trade-off (crossover point) affect the distortion performance of the woofer/tweeter? Is the PTT1.3T really able to play that low without risks??yes and SB6 crosses much lower
Maybe a helpful analogy is that at low frequencies, the box acts like a uniform pressure vessel, and the porosity of the foam is essentially transparent to these (virtually) static pressure changes. It's like pushing a plunger into a bottle that has a fully saturated sponge inside; the pressure wave from the plunger still propagates through the sponge and the glass at the other end of the bottle will still feel the force from your hand.
Tons of power is still warranted, but that's because the Purifi woofer itself is unbelievably performant (it's basically alien technology), irrespective of the box/damping. This is especially true in a PR configuration where the backwave drives the PRs, as opposed to a sealed box where it has nowhere to go. If anything, you'd maybe want to high-pass the woofer with some DSP below the tuning frequency, because the driver will unload and easily hit Xmax, especially if you watch movies or listen to EDM (where there's tons of content in the bottom two octaves where even the SPK16 will struggle). I do this for my Directiva R1s, which are crossed to a sub anyway because I live for that sub-bass, haha
When purchasing whole sheets from German timber merchants, the price per square meter is approximately €45, with a sheet size of approximately 2.99 square meters.No difference as far as I know.
Where did you get your prices from?
It’s a hell of a difference.
I priced it as precut panels (a little oversized) in case the CNC people need it that way.
A worst case scenario.
That explains the looks, are they harnessing the Protomolecule?it's basically alien technology
Thank you; I'm actually not a sir thoughThanks for the lesson sir. I’m here to learn as well as participate.
The price for cutting Valchromat to size is also unusually high in Germany.
It would actually be more economical to have a whole sheet delivered to the joinery.
