crappypanther
- Joined
- Jun 5, 2021
- Messages
- 94
- Likes
- 64
cool, but it will probably cost as much as a car. DMAX makes monitors on Purifi dynamics for reasonable money, but they also have their own dsp and amplifier
My system has 2 8" purifi woofers and the 4" midrange, and as an upgrade path a sb26adc with a 4" waveguide (augerpro based) and the off axis behaviour matches reasonably well at xo of 3.4kHz (3-way active, acourate jpol11).I guess that the 104 mm directivity is to be mated with 4" and 5.25" mid(woofer)s and the 147 mm with the 6.5"? Eventually the 8"?
In the SPK16 tech note, you explained that the wave-guide was optimized for both the tweeter and the box.
Will you provide an optimal box shape to be mated with the integrated wave-guide from both versions?
Do you have some pictures you're willing to share?My system has 2 8" purifi woofers and the 4" midrange, and as an upgrade path a sb26adc with a 4" waveguide (augerpro based) and the off axis behaviour matches reasonably well at xo of 3.4kHz (3-way active, acourate jpol11).
The purifi 104mm is fit-wise a drop in replacement, but its radiation is based on infinite baffle, so i already have the top portion of my enclosure replicated for measuring with foam and 3D print of baffle. (My enclosure weighs some 70 plus kilos;-))
Will be interesting project when they arrive!
Those are LED candles.
Some pictures:
Here a view from the kitchen into the livingroom:
Last year may serious upgrade underway:
Total height 113cm.
Some pictures:
Total height 113cm.
I received the 104 tweeters today and have only had a chance to test one outside a box, but it appears to operate as advertised in the higher frequencies. However, when I ordered my samples I was not aware that a larger version (the 147) was in the works and assumed that what I was receiving could be crossed at 1500 Hz or a little lower and might work with the 8" woofer in a large 2-way design. What is the lowest recommended crossover point for the 104?the coming 147mm WG is optimised for the Spk16 box. we may do a larger (eg 176mm) that matches the 8” in a slightly bigger box. the current 104mm version is optimised for infinite baffle, not for a particular box shape.
And I'm sure it's an excellent cake. I just don't want to design a speaker that will be, from a marketing standpoint, obsolete in 6 months.Dear Dennis,
As you know, how low you go is a matter of SPL/dynamic range requirement.
I don’t think the IEC285 power handling has been completed yet; but I shall let Lars fill you in. As you may know, it is a particularly grueling test, based on 100 hours continuous power with a shaped sine wave without damage. The AES is a little gentler, at only 2 hours without damage.
Based on lab grade distortion measurements taken of a prototype, my calculations is that
it can handle a HPF for acoustic LR4@1KHz with SPL of 110dB
With the crossover in place, at @110dB over 2-10KHz), at 500Hz, H2 is about -48dB; H3 is -50dB. Whether that SPL is high enough for you, or distortion low enough for you, depends on your intended application, of course.
BUT, don't forget that maintains a wide dispersion like a tweeter without a WG, but behaves with constant directivity like a tweeter with a waveguide, and plays as low as a tweeter with a WG.
You can have your cake, and eat it too!
best regards,
Thanh
Guitly as charged, i like to stand up sometimes without the speaker going to pot.
