• WANTED: Happy members who like to discuss audio and other topics related to our interest. Desire to learn and share knowledge of science required as is 20 years of participation in forums (not all true). Come here to have fun, be ready to be teased and not take online life too seriously. We now measure and review equipment for free! Click here for details.
Purifi EVAL input - SE vs XLR balanced
Indianapolis
#1
So I have a Purifi EVAL based unit which has XLR only input and utilizing a Speakon to banana adapter output. I have a single ended streamer/DAC source. I have a SE to XLR adapter cable and a Schiit Magnius line level headphone amp with preamp function that accepts SE input and converts to balanced and outputs a balanced XLR output. There is a very discernible difference when I choose to interpose the Magnius. Why should this be? The SE to XLR is a Stage Right Monoprice. Is the Magnius doing something to supplement/subsidize the Hypex buffer section on the EVAL unit?
N
Indianapolis
Thread Starter #2
Not much interest/response. I’m going to attribute it to level matching differences. The Magnius input is prob higher/louder so sounds “better”.
yodog
#3
If the magnus has a built in conversion process then it will sound louder becsuse it’s legit converting it from se to balanced. If you’re just using an adapter that doesn’t convert it it just adapts it so they can at least play. I don’t think it gets the additional benefit of increased voltage like with true se to differential buffering/conversion
#4
Any components in the signal path are going add distortion and noise. Schiit is not in reputation to any good to the signal. The easiest way to hook up SE --> balanced is with a properly connected adapter cable. Hypex has good instructions on one white paper on their website. It's easy to DIY, but if you decide to buy, double check the wiring as per Hypex instructions.
Similar threads
