Purifi 1ET9040BA (Eval5) monoblocks: Cobra-S2 SMPS, dual-chamber Takachi build
Boes
After months of planning, component selection and chassis work, my pair of Purifi 1ET9040BA monoblocks is finished. I'm posting the internals here because this crowd will probably have the most useful critique.
Build summary (per monoblock)
  • Amplifier: Purifi 1ET9040BA (Eval5)
  • Supply: Microaudio Smps Cobra-S2, 40,000µF on board plus an additional 4×10,000µF
  • Enclosure: Takachi HY88-33-33SS
  • Wiring: 12 AWG tri-rated cable, JST VL connectors, counter-wound harnesses
Layout
An aluminium plate splits the chassis into two chambers, with the supply on one side and the module on the other. The DC crossing between the chambers uses counter-wound harnesses to keep the loop area small. The goal was to keep the SMPS well away from the input stage.
Gain structure
The source is a Topping D900, which delivers 13 Vrms. That's enough level to bypass the Eval5's input gain stage and run only the module's 14.4 dB. The idea is a shorter signal path with less gain, and therefore less noise, ahead of the module.
Subjective impression (unmeasured)
I haven't measured these, so take this for what it is. On sparse material, such as a single voice or a solo guitar, the background seems quieter than I'm used to. I'd like to think the clean layout and gain structure contribute, but this is most likely psychoacoustics messing with me.
System
Roon Bridge on a Radxa Rock 5C → Topping D900 → Purifi monoblocks → JM Lab DB 29 (I know I need to upgrade)
Thanks
Thanks to Sami at Microaudio Smps and to Takachi for their help along the way. Credit also goes to Bruno Putzeys: from UcD to Ncore to Eigentakt, his work is the reason a hobbyist can build something like this at home.
Happy to post more photos or answer questions. I'm also willing to share the enclosure design files with anyone planning a similar build; just ask.
Is the extra 40,000µF doing anything measurable with the Cobra-S2, or is it redundant? Any thoughts?
Nice.
The 9040 being bridged, the capacitor bank is useless.
Super crisp looking build especially with the 900, nice job.
And the snr is probably excellent whether or not the caps are any use.
Nice.
Hmm, I was thinking of building an Eval9 (2ch 1ET6525SA) I have the same buffer and was wondering if it would be beneficial?
I would use a thick, angled alu sheet connecting the Purifi module to the heatshink (like the PSU does) so to take full advantage of it.
Depends the power supply. If you go with a MA, a capacitor bank can be helpful. With an Hypex SMPS1200, it is useless.
Thanks for the reply, I bought the buffer with an MA SMPS1K-SN for a different project that went down a different path so I'm looking for a use for both.
Layout
Gain structure
System
Thanks
View attachment 562188View attachment 562189
Very nice!
Very nice case! I bet the cooling is superb.
I used thermal pads underneath the purifi module and on both sides of the power supply cooling fin.
The chasis never gets hot. But I haven't played for long time at high volume levels. My neighbours would complain.
Awesome build, I would also skip the capacitor bank but still, you should get huge pride of ownership.
Nice build, I do not get why to use input buffer. When you use XLR balanced sources. Most balanced sources can drive 600ohm load and have between 4 and 10Vrms output.
I use all class-d modules from hypex oem and purify without inputbuffer. Did a lot of testing, for me this way sounds best.
My source is diy 8 channel dac as 2 x 4 active crossover.
https://www.diyaudio.com/community/...urifi-1et400a-amps.379211/page-2#post-6981958
A "normal" opamp in 600 Ohm load will have good performance in 1 kHz, a lot less above 5 kHz. Additionally most balanced sources do not go above 4 V RMS. Without buffer this allows outputting around 60 W from the amp.
As a manufacturer of amplifiers with gain settable buffers, I can tell you that a lot of people subjectively prefer having a lot of gain. While I personally prefer the lowest gain possible. So the keyword here is "for me".
Nice build. You got away with it, but some switching power supplies get actively unhappy with a lot of capacitance added to the output.
Every respectable source has output drivers(opamps) capable of driving at least 20mA. For most class-d modules with 1.8 till 2.2k impedance and 8Vrms for full output you only need 4mA at 8Vrms (2k impedance).
I always try to use as less possible stages in my audio path.
Some op-amps are ok driving 600 ohms, but if you study the distortion curves, most are really better driving more like 1k or even 2k.
