Purifi 1et400a issues
dmb4312
Hi to all,
I have had this VTV Stereo 1et400a x 2 amp with vtv custom input buffer and weiss filters
All working fine with home theathre and music/movie playing. used in spaced environment, never getting hot.
driving 4ohm 90db pair.
yesterday while playing music at halv volume suddently this noise appeared.
at fist I thought it was a music effect but muting the sound revealed the horrible noise from right channel's twitter
today I decided to swap the modules between the channels
the noise appeard on the opposite channel.
my conclusion is that the module itself is failing
I see that both modules have date stamp of 2019 (Q2 and Q3 marked by pen, Q2 is the culpit.
not sure if 2019 is the patent or production year or where to look for that.
is that all these modules are giving, at max 7 years of light usage, have search and cannot find anyone with problems with modules itself
is it possible to measure/test/repair these?
and at last, I see that purifi still sells these modules but also 1et6525sa model.
I guess if buying a replacement module I cannot have one of each models?
I was thinking what is the second one also is in degrading state and will fail soon, should I just replace both to newer 6525(these should be drop-in replacement)
noise-video:
You should definitely have two of the same module no matter what.
As for that sound, I’m far from the most qualified person here at ASR to comment on it, but to me it sounds like a failed or failing capacitor or other component that’s involved in filtering the power supply somewhere along the line.
From my experience these modules are rock solid
You can contact Purifi if VTV is of no help.
They do not have the same gain, so no.
Unless a terrible implementation was done, this would be really bad luck.
I appreciate your replies,
The amp is a VTV product, I havent done anything with it.
I have used it with another - more power hungry speakers(4ohm 400w) for some hours lately before reverting back.
But that shouldn't be problem for that kind of amp.
Okay, thanks for the input.
I have contacted the Purifi for support.
Will update here when I get a reply from them.
Purifi came back to me and asked for voltage measurements, measured ouput voltage on the PSU and buffer-boards to be withing specs.
But
After inspecting the module today I found something which also is seen on the first photo(how could I not see that), burnt Vdc and ground pins.
attaching better photos
wow
Do not turn it on and especially do not connect the speakers. Wait for Purifi advice - send them the photo.
Yeah, no, I wouldn't
Already sent; ..to be continued
The next pin after those 2 already changed color. It must get pretty hot there.
It also looks like there is some brown on that cap. Which might be the photo, or just dirt. But looks like burnt copper color to me.
That residue must be due to the burnt pins
To burn the pins shown, one would need current of tens of Amperes for enough time to create melting energy. It must have been very serious failure.
And, to me at least, looks like some pins with bad and missing solder.
It did not flow through the hole, hopefully OK from the solder side (bottom).
Yes, the soldering has been done from the underside of the board. Everything looks good to the eye besides the damage.
After a dialog with Purifi the support presumed that a metal object must've somehow touched the pins. I doubt that this is the case here.
I assume that because of that presumption and that the module is out of warranty I had to buy a new module; luckily they still have them in stock.
A little digression:
I lot the amp stay powered on with the remaining module on "problem" channel for 6 hours without issues.
hopefully I dont need to worry about buying anoher module for a while.
Cheers
The melted pins are 1 positive power rail for a total of 2 and one power ground pin out of a total of 6. All the other pins are in perfect state. The hypothesis of the short of two adjacent pins by an external object perfectly makes sense.
Hypothetically yes.
There is nothing loose in the amp
The amp was stationary when the issue occured
The only probable cause I can imagine is that when I moved it prior, something came loose inside.(All boards/modules are fastened from bottom of the case)
or
fall off of me and landed inside the amp case through a group of holes with diameter of 2.5mm
To me it doesn't make sense.
Anyway, my amp - my fault
I will check thoroughly inside the case for something loose and let you all know if I find something.
Maybe too late now, but if it was a lose object it must be somewhere. Unless it burned away.
The capacitor seems to have signs of mechanical things happening? Not just the heat damage formation from the pins.
Absolutely nothing moving in the case or fell out when you opened it? I'd also look if something is stuck in another place now. Like a lose screw.
Nice riddle.
Pure speculation: an insect as the culprit? They are conductive...
