Soundproof
- Joined
- Jun 20, 2026
- Messages
- 734
- Likes
- 690
Sure, but if that's what people need to do, that's what people need to do. I do know for a fact that some people and organisations put a hold on EV specifically due to lack of towing capacity, and for a SUV that will be an important point of consideration to me and many others. The new EU weight limits will make this easier, although for EV's it's a construction consideration too.Towing with an EV in general is an efficiency killer and thus a range killer. At present, if you are towing, I would go ICE.
EVs do weigh more due to the obvious weight of the battery. This can affect tire wear if one is not careful. New EV tires are getting better. The heavier a vehicle the more road wear it creates, though you really have to get into the weight of heavy trucks and semis before wearing of road surfaces is an issue. If you look into the data or road surface wear, semi-trucks are the main cause of major highway and, particularly, Interstate road wear.
It's a requirement, like for a van. It should have a flat inboard surface area of min 1220 mm x 2440 mm (abt 4 ft x 8 ft) plus clearance for straps and handling of typical wooden construction plates or 3 euro pallets (800mm x 1200 mm). Builders prefer that for trailers too.
Please do allow me to rephrase: Charging capacity for homes would typically be 11 kW up to 22 kW.My home chargers are 7.2kwh max. I think one of them is turned down from that, though. Also, home chargers really aren't. The charger is on the car. The wall thing is a fancy switch.
Out of courtesy I checked for Porsche Taycan 4 Cross Turismo 2027: The on the wall box is capable of 22 kW and the Mobile Charger capable of 11 kW. You'll pick the cable suitable to your home/cabin. With an EV I would likely have to pay abt usd 40 to 50 more per month for the utilisation of capacity, consumption not included. Upgrading of wiring/fuseboxes ++ to handle 22 kW will vary. Most would need a bit of digging hereabout, and that can be expensive.
