I agree about not limiting a discussion on «punch» to lower frequencies. Maybe one needs to bend or break the rules a bit?
The Fenton and Lee paper that I referred to in the OP demonstrated that «punch» is a lower frequency phenomenon, but I wonder if «punch» is a limiting term. Could «punch» be defined as something which is frequency independent?
The reason why I came to think about «punch» and making this thread started in the opposite end of the low frequencies. I auditioned a new speaker, the two-way Genelec S360, which uses a compression tweeter and a 10 inch woofer. The tweeter is highly efficient, and it was the tweeter that got me reflecting about speed, or «punch».
What happens in a highly efficient driver? Well,
@John_Siau has written about the first watt and how higher power leads to distortion in drivers (
https://benchmarkmedia.com/blogs/application_notes/power-amplifiers-the-importance-of-the-first-watt). I don’t know and am just speculating: Could highly efficient drivers be a source of «punch», «snappiness», especially as you move up in frequency where our hearing is more «accurate»?
I auditioned the S360 against Genelec 8351 and the high frequency difference was obvious (as it should be). Previously, compression drivers were shunned in hifi speakers for obvious reasons. However, recently Phil Ward of Sound on Sound wrote the following
«Compression drivers are most often found on speakers designed for live‑sound applications, where efficiency, very high volume capability and reliability are priorities — sometimes, it has to be said, at the expense of sound quality. Having 'dissed' compression drivers, however, my experience of the JBL 7 Series monitors, reviewed in the February 2018 issue, showed that these days they can definitely be made to compete on sound‑quality terms with direct‑radiating drivers (...) I wonder if advances in computer modelling of diaphragm behaviour are enabling diaphragm materials and profiles that were previously considered as only good for less demanding PA applications to become viable for high‑accuracy monitoring?»
Source:
https://www.soundonsound.com/reviews/genelec-s360
So I wonder if «punch», if that is the right word, has to do with higher frequencies as well. Which makes me wonder if «punch» should be liberated from a discussion of certain frequencies because «punch» is a quality that streteches over the entire frequency area.
Does that make sense?
