PSUs for TPA3255 amps when max power desired
Of course, these are off-the-shelf power supplies from specialized manufacturers. Neither 3E Audio nor Aiyima—nor other amplifier manufacturers—produce switching power supplies, and that is a good thing.
Yes ofc.
However I'll pay a little more for a unit sold by a real brand with reputation at risk
as opposed to a random flash deal from Ali
At Amazon USA, Fosi Audio resells this 'Huntkey' 48 volt, 10 ampere external power supply that is non-adjustable and comes with a U.L. listing:
Yes ofc.
Both Jyhpower and Huntkey are proven, well-known manufacturers in the supply industry, recognized for their quality and in-house testing facilities. Jyhpower has been in business for over 15 years, and Huntkey for over 30.
Both manufacturers have operated under ISO9001 certification for more than a decade, and their products meet European and American safety standards and regulations, including RoHS and REACH.
Both are also considered leading manufacturers of GaN-based power supplies and chargers.
If these two major manufacturers aren't considered established, can you name any that are?
To the best of my knowledge, manufacturers better known in the consumer market—such as Mean Well or TDK—do not offer ready-to-use "brick-style" power supplies suitable for standard amplifiers.
So now I know, thanks.
I meant the recognized Amp brands, even if the OEM is unknown.
But adjustable bench supplies AFAIC are even better, lots of flexibility.
Going from 48V to 51.5V might just be what's needed.
However for the purpose if the thread BETTER VALUE comes from lower price so long as reliability, non interference etc.
$100 for a plain brick is IMO not reasonable.
suspiciously cheap, but they accept PayPal
Creadvent Audio 48V 10A DC Power Supply
shipping +32 for me
I bought this psu but it shut off as soon as It reached around 4 amps. My unit may have been a dud though. I returned it. I couldn't find any reviews or tests on it either so maybe if you get it then report back if it can do the full advertised 10A.
Are these available for the US market without risk of tariff issues?
I think so. If amazon US works like it does here and handles import/tariffs, so that you have final prices.
I set shipment to some random zip code that came out to be Pasadena. Check sender and availablity for your location of course.
IcePower 200AS1 is not a TPA3255 module
You mean this one, right? The 200ASC module you may be thinking of is out of production; it was a discrete module similar to 300ASC (now 300AS1). The 200AS1 module shown here is using the TPA3255.
100AS1 and 100AS2 modules use TPA3251.
200AS1 and 200AS2 module use TPA3255.
200ASC was an earlier single-channel 200W module that used a discrete output stage.
The TPA3255 chip in PBTL configuration is located under the two screws you see on the right side of the image (viewed from below the module).
Relevant, corrections welcome
I agree that going to a lower VOLTAGE - if you do not need to get maximum power out of your amplifier - can help a bit with longevity
about the same impact as only cycling LI batteries between 20-80%
However since amperes current is only drawn by the amplifier according to use of the volume knob, the only thing buying a lower ampere spec PSU might get you is saving a little money. Buying a PSU capable of supplying 25A makes no difference if your amplifier never pulls more than 5A.
If you REALLY want to optimize this stuff, invest in an adjustable bench supply, feed your amp 42V most of the time, and when you want the extra SPL dial it up to 48V
Or 51V for a 3e A7 mono I don't think any TPA3255 can deliver higher output from a 10A supply.
Such things cost a little more, but really, not so much.
