How would this create a ground loop? waht is the "loop". I would expect the test setup to be a line not a loop?In this case, I suspect a ground loop was created causing the increased 60 Hz mains spike. But I can't explain why the 180 Hz third harmonic has also gotten worse. Either way, we have gone backward.
To be pedantic, sometimes dither is psuedo-random "noise" that is digitally removed later in processing.Don't call it noise. It's dither, stupid.
Jokes do not survive pedantry. Even bad ones don't make it.To be pedantic, sometimes dither is psuedo-random "noise" that is digitally removed later in processing.
i did say I was being pedanticJokes do not survive pedantry. Even bad ones don't make it.
Don't give them ideas. soon they will start saying that electricity from Coal power plant is the best, you should not be using renewable energy because it's garbage for audio (facepalm)The only improvement in terms of power supply for audio gear is using nuclear power plants. Then you get really deep and sub atomar base-response and very bright and radiating heights as never heard before. ;-)
Well, maybe you can't. But I can hear the difference coal makes.Don't give them ideas. soon they will start saying that electricity from Coal power plant is the best, you should not be using renewable energy because it's garbage for audio (facepalm)
Lol the whole idea of converting AC into DC then into AC and then finally into DC seems rather repetitive, pointless, inefficient , and overtly complicated
The competition would then say "create your own unique sound experience by powering your gear with our audiophile dynamo bike, losing weight at the same time".Don't give them ideas. soon they will start saying that electricity from Coal power plant is the best, you should not be using renewable energy because it's garbage for audio (facepalm)
Amir, you know what you must do.... for science!As with tests of other PS Audio PowerPlants (of which, I own one myself but never use)
Stupid? Rather gullible IMHO, nobody is born with knowledge. People believe in stranger things than this, as long as the person(s) behind the narrative seem credible to them. And, if the narrative reaches millions and only one per mille will buy, it still means thousands of units sold.I dont know how it's possible in the 2022 to produce and buy this toys ...... it's incredible, the "audiophile" people it is too stupid? Bah .....
I dont know how it's possible in the 2022 to produce and buy this toys ...... it's incredible.
but then, careful what you say about the smellAmir, you know what you must do.... for science!
Collect as many PS Audio PowerPlants in one place as possible. Now daisy-chain them, plugging one into the next, for multiple levels of filtering. Surely this will create an audio experience so pure, you'll be able to smell the brand of deodorant that Norah Jones' producer used on the day of the recording.
