- Joined
- Nov 16, 2021
- Messages
- 203
- Likes
- 1,113
Well, you're right about a few things, certainly, even in the last few months of R&D.I can predict the following changes in PS Audio speakers based on this:
1) Change from planar transducers to point-source, moving coil drivers, since a point source provides more symmetrical radiation and a moving coil platform suffers less nonlinear distortion.
2) Introduction of a HF and possibly MF waveguide, for controlled and matched dispersion.
3) Driver arrays will group LF drivers closer to the HF and MF components instead of clustering woofers of a tower speaker near the floor.
4) A coincident midrange-tweeter array will provide symmetrical vertical and horizontal radiation. Possibly with cardioid radiation of the rear wave to control horizontal dispersion beyond the ability of the waveguide at lower midrange frequencies.
5) Powered cardioid bass in more complex assemblies.
6) Hard metallic-oxide diaphragms instead of fiber constructions
CEA2034 methodology favors speakers exhibiting a specific set of behaviors, so the only speakers that will appear to measure 'well' are those that fully embrace its dictates and assumptions. If your weather vane is properly calibrated, you will see which direction the wind is blowing. Many formerly perfectly acceptable speakers are now landfill.
1. I am am looking at other tweeter solutions and want to use the best tweeter for the job, regardless of nostalgia or uniqueness in the marketplace. I'm doing some rigorous evaluation of AMTs and, yes, domes.
2. The reason for #1 is partly number 2. Our tweeter doesn't work perfectly on a waveguide due to a non-planar wavefront occurring at about 10 kHz and the front magnet structure forming a cavity resonance around 15 kHz. I've been testing some custom AMTs and domes that perform essentially textbook perfect.
a. Our large planar mid performs very well (when the crossover point to it is sufficiently low to keep directivity uniform) so I'm planning on using it for some upcoming designs , with others less expensive models using quality cone mids.
3. The CTA-2034 measurements don't factor in the effect of floor bounce. I was seeking to minimize floor bounce (more effectively in some towers than others) with the baffle placement I chose previously but I think you're right that tightly flanking the mid with woofers (in a three way) is typically a better approach with the higher than typical crossover points we use on our planar mids.
4/5 I would eventually like to work on this but there are major "packaging" challenges with this when using acoustic waveguides. Yes, a cardioid or essentially a damped dipole could be an interesting options though, to extend that low enough would require an active solution. I haven't don't research on this and this isn't in the next product cycle, though I am working on an active speaker. Cardioid isn't necessarily a panacea. There are some great implementation of it from Gradient (for many years), Dutch & Dutch, Kii but, looking at Amir's measurements of the Palmer speaker, getting the implementation right can be challenging and sometimes integrating the lower monopole bass section a little more challenging. You can still make a speaker sound great with a traditional radiation pattern.
6. I like aluminum woofers but don't love aluminum mids most of the time because the driver's own harmonic distortion can excite the cone modes. Purifi has a good paper on how to minimize current based distortion with passive notch filters for this though (https://purifi-audio.com/blog/app-notes-2/low-distortion-filter-for-ptt6-5x04-naa-11) It's really hard to beat a good paper cone, as there is so much adjustment that can be made to the stiffness and damping properties.
For our eventual high end line refresh, I have been working with some spread tow carbon fiber (similar to Textreme but not from that vendor) with good results and I'll likely go that direction. I have been working with a driver vendor who works with Sonus Faber, Mofi and others who I've been developing some less expensive paper cone drivers that I'm very happy with the cone performance on (they're incredibly smooth and extended).
Don't get me wrong, there are a lot of good metal cone drivers out there. KEF does something quite interesting where they took the technology from their mechanical uni-Q (there the center dust cap mas a mechanical crossover where the surround decouples form the cone at HF and used that simulation tool to make a compliant attachment from the former to cone on some of their aluminum mids where it decouples the first breakup mode of the cone. Anyway, aluminum can be made to be very high performance but it's not my first choice, generally. You can still get great performance, distortion and directivity with other materials.
At some point, I'll do a posting to share some of the klippel data on the new drive units and show the in-house FEA tool and sim work that went into them. I promised to do some videos and some of the stuff mentioned here would be good topics to dig into.
