respice finem
- Joined
- Feb 1, 2021
- Messages
- 4,330
- Likes
- 8,615
Now they probably matterSo....I am confused by this. Aren't these the guys that say measurements don't matter etc?
I don't think many of those listed own a NFS. Klippel has many more products in its range,Here's a list, looks incomplete though:
I had gathered that. Not sure what the lower cutoff frequency is though. To accommodate 20Hz the 1/4 wavelength absorbent wedges would be approx. 14 feet. On all sides and top and bottom of the test space. So the overall chamber would be the size of a decent concert hall. KEF perhaps uses open air measurement for very low frequencies? Whatever the case not many other loudspeaker manufacturers do as good a job.Anechoic chamber, since the 1970s.
I doubt it is large, and a Klippel would better I agree. Maybe they have one now I don't know, but they were one of the few speaker companies that were doing things properly fifty-odd years back. Their flagship speakers from late 70s on are still competitive with modern designs.I had gathered that. Not sure what the lower cutoff frequency is though. To accommodate 20Hz the 1/4 wavelength absorbent wedges would be approx. 14 feet. On all sides and top and bottom of the test space.
It's highly unlikely they would try to use the anechoic chamber to get that low when there are easier ways to get accurate results... Ground plane, mic in the box, nearfield + farfield merged. As seriously as they take measurements, I wouldn't be surprised if they use all 3....Not sure what the lower cutoff frequency is though. To accommodate 20Hz the 1/4 wavelength absorbent wedges would be approx. 14 feet...
They likely use calibration below 80 Hz as Harman does with their anechoic chamber.It's highly unlikely they would try to use the anechoic chamber to get that low when there are easier ways to get accurate results... Ground plane, mic in the box, nearfield + farfield merged. As seriously as they take measurements, I wouldn't be surprised if they use all 3.
Yes. Based on this article, KEF was doing something similar back in 1994.They likely use calibration below 80 Hz as Harman does with their anechoic chamber.
I learned a new word today.If you're admiring a speaker's/Amp's/Converter's beauty and emotion, then you've truly lost the plot and I wish you a speedy resipiscence.
WOW, I remember when the Klippel measurement system was a fairly rare piece of gear. !Here's a list, looks incomplete though:
"You've come a long way baby" since I bought his PS III phono amp back around 1981 on the basis of Peter Aczels review in the "1979 V2-#2 Audio Critic". Cost me the staggering sum of $222 plus tax! Sounded Good To Me, 47 years ago.Paul can't be too bad of a businessman, so it's possible they reach agreement on that ground.
It appears that KEF utilizes a kind of rotating microphone array with the speaker being tested sitting at the center of the rotational axis, with the entire measurement process taking place inside of an anechoic chamber. Judging by the comments from the a manufacturing representative, this apparatus costs quite a bit more than the Klippel NFS.All the gear and no idea? Obviously you have to know how to use the equipment, how to interpret the results and how to modify the design (that might be the hard part!).
Your point about simpler measuring tools is well made. I don’t believe that KEF has a Klippel but their loudspeakers are pretty good.
EDIT typo
It is my understanding, from my very casual readings, that a Strad has never won a blind test. There may be other reasons to want one, but it does not sound better. So, I guess a lot like a luxury speaker.It is 1716, and Antonio Stradivari’s violin is rejected because it did not measure well enough.![]()
Judging by the cat, Ayre gear up there must truly operate at class AAs already pointed out KEF uses a motorized microphone array (developed by KEF) in an anechoic chamber. The older interview of Jack Oclee-Brown from KEF by John Atkinson (Stereophile) from 2017 also provides some interesting measurement technique details (15ms quasi anechoic measurements, ground plane outdoor measurements) and is really fun to watch in general:
