Hope you will send your subwoofers and loudspeakers to some reviewer with very thorough measurements (like for example Erin) to see how well you do them.
It's under consideration, especially the speakers. The problem with subwoofer measurements/reviews as carried out by Erin and Amir is that it's typically based on CEA2010, which focus almost entirely on maximum output, often weighted against cost - as a result of subwoofers being used mainly for home cinema where maximum low end output is more important than size and visuals, and even sound quality.
Our subwoofers focus on size / ease of placement combined with high sound quality, with focus on music systems rather than home cinema systems. If you want maximum SPL per dollar with no other considerations, our subwoofers are obviously the wrong choice.
That being said we will still share the typical measurements you would get from such a review, so it will be available. Some have been shared in this thread already, will make new measurements of the pre production models. Since the cabinets are now relatively small, the low end extension will likely be somewhat less than the prototype.
Happy for
@hardisj to share his thinking / approach on testing something like this (a 3500USD subwoofer that has other design goals than maximum SPL).
