Properties of speakers that creates a large and precise soundstage
I generally like the beginning of the stereo sound field, starting closer to me for more immersion, and so far I still haven’t experienced the precision and layering of imaging as when I have my two channel speakers pulled well out from the wall.
The "speakers pulled well out from the wall" setup geometry results in a longer time interval between the direct sound and the onset of at least some of the first horizontal-plane reflections, and imo having this time interval be as long as is reasonably feasible is beneficial if the priority is a "you are there" presentation. It is NOT necessarily beneficial for other priorities.
What do you mean by "the beginning of the stereo sound field"? Do you mean you like the vocals and instruments placed closer to you, or the ambiance of the track extending closer to you, or something else?
Essentially yes, both.
Of course it depends on how the recording was done, but I like the feeling of the recorded space taking over my room, and sort of transporting me, as well as if instruments are recorded up close, they are up close (at least at what I find to be a comfortable distance). But it’s mostly about the sense of how the recorded space will tend to merge with my room and dominate it more, and I get less of that affect the further the speakers are away from me or then it becomes. I’m in a different room and I’m looking at a distance to a sort of porthole into a different recording space.
Perhaps slightly tangential, but…
Joseph Audio set ups, have long been praised for their expansive soundstaging and precise imaging.
Jeff Joseph in particular has something of a reputation for getting really good at sound at shows while many other rooms struggle.
For a long time at shows, he’s often placed his speakers on the diagonal of the room. So that the room corner is behind the speakers:
What would be the advantages (and possible disadvantages) of that set up? Has anybody tried setting up their speakers on the room diagonal like that? (My room set up wouldn’t allow it).
First thing that comes to mind is almost no first reflections from the "side" walls, except insofar as his speakers radiate 180 degrees. I'm certain there is further analysis that could be done, which I am not qualified to attempt.
I did this type of experiment.
Exactly as you say, by delaying the first early lateral reflection in time, you lower the frequencies of the reflection on the wall.
Also different coupling to room modes for each speaker (if the room is not square and/or distances to the corner for the two speakers are different).
My recollection is that @Floyd Toole used a diagonal setup geometry in the smaller of his two rooms in his previous home in Canada (the other room was the big room with the Mirage M1's).
With a diagonal configuration, the first significant lateral reflections will come from an unusual direction, often somewhat behind and to the sides of the listening area. Imo THAT now becomes the location where the reflection energy needs attention, either by re-directing or diffusing or (last resort) absorbing it. An open doorway in the right location makes a perfect wideband absorber.
Ime if those first behind-and-to-the-side lateral reflections are not addressed, the spatial quality can have a somewhat "claustrophobic" feel, presumably because the combination of arrival time and arrival direction of those reflections. But address those reflections and ime the spatial quality can be really good.
The room is the final audio component and, as such, it can make or break a truly satisfying listening experience. All rooms are different, so a truly guaranteed recipe for success doesn’t exist. We all hope for good luck but, most often, things need help to ensure a really successful marriage of loudspeakers and room acoustics.
To keep things simple, let us separate the acoustical issues. First, is the shape of the room. Rectangular rooms are fine. Splayed walls, or other exotic shapes are not necessary for good sound. L-shaped rooms and three-sided rooms force us to be more creative, but can also work well. A diagonal arrangement, with the TV in a corner, is superb, which is fortunate, as it is often forced on us by windows, doors, fireplaces, etc. Note that the surround speakers are to the sides of the listeners, not behind them. --Floyd Toole, "Understanding Room Acoustics and Speaker Placement "
Trip hazard!
In some rooms this is a very suitable measure in order to avoid asymmetrical side-wall reflections and room mode excitement alike.
By the way, I’m curious if other people here have experimented with really wide spacing between their stereo speakers.
My normal set up is something like 8 feet between the speakers and a seven or 8 foot listening distance.
But both my Thiel 2.7 and Joseph speakers hold up quite well with much wider spacing in terms of still maintaining center fill imaging.
Sometimes I’ve spaced them out more like 10 or 11 feet apart, right to the side of the room, with me about seven or 8 feet listening distance. This is always tons of fun - a truly panoramic experience where the speakers are practically gone from the field of vision and it’s just this vast soundscape, with enough imaging precision that I can still easily hear the relationship between all the instruments. I personally don’t end up sticking with that set up because in my room, it tends to emphasize the bass a bit more, limits the sweet spot a bit more, and can give a bit more of “ sameness” to the soundstage presentation versus the speakers being closer together.
Anybody else experiment with super wide set ups for their loudspeakers?
The closest I've got to that, is by comparing wider radiating speaker with narrower. So at one of my friends house, his JM-lab Focal Alto Utopia BE has a much wider dispersion than my DIY KEF speakers. But he has a wider spacing between the speakers, which I believe helps with a bit clearer image between the speakers.
Mine are more than a meter closer together, and I sit a bit closer - maybe half a meter. Still, my speakers present a better imaging.
I guess you have to find the best compromise, regarding your room, damping, listening position and type of radiation/dispersion from your chosen speakers :)
All that highly directional speakers achieve is exposing the speakers as the obvious source of all of the sound, like a pair of megaphones.
While this would be true if such speakers are set up for traditional stereo triangle, their true benefits may be recognized in time intensity trading configuration:
Apart from superior image stability and pinpoint localization, in a right setup it may be the case that sidewall reflections are stronger from the opposite speaker, having longer path and further delayed while having similar spectra. I have no idea if this complies with your theory though, which I find interesting.
Linear phase crossover between the tweeter and midrange.
And what can you say about crossover between the woofer and midrange? For example, at a frequency of 300 or 800 hertz?
I don't remember and wasn't immediately able to find the full post you quoted (which must be a year old or more?), can you elaborate on the context?
I see now your quote was from the very first post in this thread. :)
My understanding and experience is that we're most sensitive to phase shift in the higher frequencies. Crossovers with slow / steady (not abrupt) changes in phase shift between midrange and woofer is probably less of a problem (not that a phase shift between tweeter and midrange can be characterized as a huge issue either).
Will you make a bigger speaker than the Manta?
In a sense, yes, since the Manta Sentinel is currently in development. Which is a Manta speaker system with dual 2x15" subwoofers. So a system with 2x12" in the midbass and a total of four 15" drivers in the bass.
More info here (and should probably be discussed further there rather than in this thread about soundstage):
I would say audibility of properly constructed standard crossovers >1 kHz is nil, if anything phase linearity should be in low f crossovers.
I would say audibility is quite much lower threshold than the often cited 1-1.5 cycle at 100-200 Hz.
