Very cool so far. Did you create the frame for the grille and 3D print it?
Yes! Everything but the sidepanels and electric parts are 3d printed.Very cool so far. Did you create the frame for the grille and 3D print it?
That 1%? Woofer screws?Looking very spiffy there. So close. Thing is like 99% there in terms of looking like a commercial product and that's impressive.
As far as stiffness goes it's quite the same as birch ply. I used 3 0.6mm walls and 35% grid infill. I could have gone a bit higher, but I absolutely wanted to keep the halves under 1kg. Cabinet structural resonances were still above woofers band @600-700hz so I'd call this a success.Hello,
This is an brilliant result and innovative way to proceed. For the 3D printed part, which level of infill did you used? Do you consider that it is the right one, or would increase/lower it ?
Does it "rings" different from wood?
JMF
You just need to upgrade your machine's flow and cooling capability so you can print with larger nozzles. These averaged around 27 hours per half so it's not too bad.Thanks a lot for this feedback. Your project demonstrates that 3D printing makes sense for speakers, with reasonnable infill. Working with halves solves prart of the issue related to the bed size. And printing on the side offers new possibilities.
Well done !
I imagine that it still represents very long prints...
JMF
They are also printed. The fabric is glued from the front side just from the lowest point around the 'dustcap' and from the backside.Nice looking speaker!
Did I miss how you made those grills? Or just purchased (source)?
This filament is matte high temperature pla that I got from anycubic surprise box. High temperature means that it's designed to withstand annealing, which is process I did not use so it's basically just matte pla+ that prints great.Hi @KamuDesigns , amazing project! I got my first 3D prints done a couple of weeks ago and learning on the go.
For electronics enclosures i am using PETG because I am afraid that PLA starts to soft if electronics get a bit hot and don't have a dedicated area to print ABS. But I am not finding PETG so easy to print, and worse than that, i am seeing that the dimensional stability is not great. Well, they are thermoplastic s after all. I wonder if it is worth the risk of sticking to PLA.
Seeing you have amps in there, wanted to ask you what sort of filament are you using and what is your experience being so far?
Thanks a lot!
