Project KOAN - 3-way 3D printed cabinet using Satori drivers
Surely this doesn't sound good. Why so steep?
This is something I looked into when thinking about building my own speakers a while back.
Steep filters let you cross a given tweet a bit lower as the minimum frequency you ask from it is pretty much the crossover point itself.
Having less overlap between drivers can any unwanted interference between drivers, comb filtering and so on.
And there is the notion of sound being clearer if each element of the signal is basically only coming from one driver, although I can't say whether that's really been substantiated or not.
Supposedly it can be done well if you also linearize phase in addition...
Fully agreed
Let me add some more points to it:
- Less overlap not only means lower/higher crossover points and lower IM distortion but also it means that you will have a way smaller overlap in directivity matching to take care of. With 96dB/oct it is about 1/6 of an octave altogether. That is considerably smaller vs. with 12dB/octave where you need to align +/- 1 octave....(good luck with that)
- In minimum phase mode using 48 or 96dB/oct slopes might increase the phase linearization exercise that you need to perform but since I am using linear phase crossovers that is a non-issue for me, phase remains untouched
- The issue with linear phase filters is pre-ringing but down to about 300Hz it is so small that it is not audible, even with 96dB/octave slopes. Below that I use 48dB/octave slopes. With my Janus crossover plugin pre-ringing is not audible at 80Hz (that is where I cross my woofers to the subs)
@LiveTek
Well, let me put it this way: the aim of this previous project was to find the cheapest possible non-PA drivers with excellent measurements (FR, off-axis, distortion, etc.) and see what comes out of it. The results were totally above any expectations I had. It was proven that with cheap but decent drivers one can put together a system that beats most of the """high-end""" stuff on the market.
Now the aim of this current project is to see what happens if you buy a bit more expensive speakers but with equally even better measurements (distortion, mostly)
I am extremely curious about the results :)
They are active, as all my previous projects.
Signal chain:
Source: Windows 11 PC with Tidal
DSP: Jriver with Pataki Audio plugins and Jriver's WDM driver
The tweeters and the mids are powered by two Topping LA90D amps
The woofers are powered by a Topping PA7 Plus amp
The subs are powered by two 3e Audio A7 Mono amps
Exactly, and that was a known design element. It can easily be corrected with DSP
The 9.5" Satori paper cone is one of the best values in a driver that size, it's used in one of my tower speakers with a crossover point similar to yours but with a passive LR24 LP. Great looking project so far, good luck with its continuance.
I heard the Satori WO24P-4 in a DIY three-way speaker at a vintage DIY fair. It sounded really good—the entire speaker did.:)
Although it was a DIY project, the builder had the help of a top-tier professional for the crossover design, a curved slot port optimized for minimal turbulence, and so on:
(apologies for the slightly blurry photos)
In that three-way DIY speaker:
Tweeter: SB SB26ADC-C000-4 (with a 3D-printed waveguide)
Midrange: SB SB15NBAC30-8
Bass: Satori WO24P-4
@ppataki glad to see you're still trying to reinvent the wheel. This project is VERY cool. I'm doing something similar but I used gyroid in the entire cavity for additional rigidity since it doesn't displace much in the way of volume (all of the pockets connect). I hope to have the paintwork done this week which means digital crossover next week. Have you adjusted your crossover design process at all? You've got a lot of experience at this point.
Thank you @312elements, much appreciated!
Good luck with your project too, I hope you will publish it here
Yes, quite a lot
Here is what I take into account to determine that:
- frequency response
- distortion
- directivity matching (as described in the first post in this thread)
I choose a crossover point where all these align in the best way possible. 96dB/oct slopes help a lot with that.
Phase linearization would normally come next but I skip that since I use linear phase crossover all the way.
I don't want to derail your build thread. This is presumably your plugin. Does it have a forum/post/YouTube channel etc where I can learn how to use it and what it does?
What I meant by "here" is ASR in general, not this specific thread :)
Yes, there is a manual, you can find it here (or by clicking on the Manual button when scrolling down to Janus on the Pataki Audio website)
Yes, quite a lot
- distortion
I'm finding it a lot harder to get things to behave well with this steep of a filter in my vcad projects. I think you'd get some insight into this if you could do vcad projects for your speakers.
I don't need your plugin, but I'll try it out. I just use fabfilterpro4 for filtering atm.
@pptaki, I checked out your site. The plugin looks very cool, but this system is linux based so it seems like it's not compatible with the plugin. You did a great job with the site and the graphics. I assume the VST's themselves are awesome too!
The first speaker is (almost) ready, only the legs are to be done
I am extremely happy with the looks :)
Once the legs are in place I will perform some measurements from the MLP, stay tuned!
Did you investigate the acoustics of the gyroid fill before deciding to fill the cavity with it? I thought it might be a good idea until I read a paper on the acoustic properties. I don't remember the details of why though. I'll try to find the paper again...
Edit: it looks like there's been a lot more work on the idea since I last looked. Back then I could only find one paper, but now there's more than a page of results.
Like anything, there are trade-offs and the filament chosen is also is part of the equation. My goal was to stiffen the walls as much as I could to drive the resonant frequency of the enclosure as high as I could. There's also the added benefit of internal reflections being dispersed. I can't tell you whether or not I succeeded in any of those tasks yet, but I'll let you know my findings. The enclosures themselves are quite dense and stiff and they'll become even more stiff when the drivers are added. The woofers are mechanically coupled to one another and side firing so their forces cancel each other out. All that to say, I don't know that there's a universal answer to the question of whether the gyroid infill is a good idea or a bad idea and it's likely more situationally dependent like most enclosure design questions. A lot of people think building enclosures out of MDF is a good idea and a lot of people don't.
And now with the legs!
I really love it! And with this I consider the first one to be fully finished
Now let's see the in-room MLP (~210cm) measurements
Frequency response using Psy smoothing. I have done the level-matching, the delay settings and then added a low shelf and a high shelf + 2 peaking filters - nothing more
I will let Dirac further iron it out
Distortion is brilliant in my opinion
IR is showing signs of narrow dispersion (that we could also see in the off-axis measurements in the first post) - even the highest reflection peaks barely go above 10% and this is a room with a double glass door and zero acoustic treatment! (yet)
Step response is showing that the drivers are time-aligned (maybe could be a tad better but Dirac will further enhance this)
And there is some non-audible pre-ringing due to the linear phase filters
I am absolutely satisfied with the measurements and looking forward to listening to them in stereo once the second one is done.
It will be interesting to compare them with my current setup which has a pretty wide dispersion.
A note about the second one: I have decided to try a different kind of CLD instead of sand - just to enrich my experience and see how it compares with sand filling the walls.
I will print the woofer's outer PLA walls with a width of 7 mm then glue 4mm butyl sheets on them and then finally glue 7mm PLA tiles on those to cover them fully from the inside.
I know it is not ideal to mix these techniques for Left-Right speakers but I am really curious and would not want to miss the opportunity to try it.
I will report back in 1-2 weeks' time with the results
View attachment 565795View attachment 565796
View attachment 565802View attachment 565803
You're already thinking about your next project aren't you?
Normally yes :)
But now the plan is that I complete this one and then give Dirac ART a try (now that it is available on a PC too, finally....)
So Dirac ART is going to be my next project
The CLD is done for the lower half of the woofer cabinet
I made a video where you can listen to three stages of the procedure:
- outer wall only
- outer wall + butyl
- outer wall + butyl + inner wall
Once the whole cabinet is put together I will perform a knock test on them for comparison.
- outer wall only
Can't argue with the "knock test". You can certainly hear the difference. It appears that your CLD is "targeted" meaning not everywhere. how do you decide and also... is that inner wall printed? How does it secure? Does it just glue to the butyl?
