I would like to share my latest speaker project here with the ASR community
After successfully building my first 3-way 3D printed modular speaker, I decided to potentially take it one step further and design and build a successor with different design ideas.
This time it will not be modular but one body only (divided into 4 printable parts + a removable waveguide) standing on a tripod
This is how the speaker will look like from the outside:
The real-life print will be 115cm high (with the legs) and will have the same colors. The black lines on the cabinet are seam grooves that will be filled with self-adhesive EPDM. All the relevant cabinet edges are rounded.
The inside:
All the driver chambers are sealed and separated from each other. The mid chamber has a tapered cylindrical shape (will be stuffed with melamine foam and polyester wad), the woofer has a sphere-like chamber (back wall will be lined with melamine, stuffed with wad).
The woofer's cabinet walls will be filled with dried sand, the parts you see all around it are actually the sand pockets with fill pipes.
The drivers are all Satori (they shall arrive tomorrow):
Tweeter: my existing Satori AT60NC-4 (AMT ribbon)
Midrange (actually a midwoofer): Satori MW16P-8 (paper)
Woofer: Satori WO24P-4 (paper)
Drivers were selected based on measurements published on hificompass.com
Tweeter-mid c-c distance will be 113mm + I have a custom designed waveguide that will allow me to apply a higher crossover point. Of course I will perform some off-axis measurements to decide on the best crossover point once printing is done. As usual, I will use my own VST3 crossover plugin with 96dB/octave, linear phase.
The mids will be crossed to the woofers probably at 400Hz and the woofer crossed to the subs at 80Hz.
Printing will take >150 hours per speaker and will require >10kg of PLA per speaker
Tomorrow I will post some pictures about the drivers then printing will start with the upper part (tweeter + waveguide + mid); followed by the off-axis measurements to decide if subsequent waveguide design iterations will be needed or not
Stay tuned!
(any questions/comments are welcome)
The inside:
Stay tuned!
