Problems with your Fosi S3
Can you perform a firmware update on your Fosi S3
  • yes
    Votes: 8 88.9%
  • no
    Votes: 1 11.1%
Hmmm...now my S3 changes its output setting on every power cycle from analog(xlr,rca) to digital. First time it happened a couple days ago I thought OK I pressed the wrong button. But now I am sure it is doing it by itself....weird.
Today came up with previous day setting of analog out.....so it is just completely random or random enough that I have not figured out the pattern yet....rinky, dinky, dink.
I received the S3 Lite about a week ago. So far it has done everything I've wanted it to do. I've been using it to stream music from Qobuz Connect, a UPNP server, and AirPlayfrom iPhone and MacOS. I've used only the USB output so far.
The only playback issue I've seen so far is that sometimes one Apple device is unable to connect to it via AirPlay after I've used it from another Apple device. I'm guessing this could be more of AirPlay2/Apple issue than a Fosi issue, not sure. It seems the last device isn't willing to relinquish its connection unless switched to another. I've been able to resolve this when it happens, but haven't spent any time troubleshooting.
No issues with firmware updates because it's not an issue for me yet. The Fosi iPhone app reports that the firmware version is up to date, and the version it reports also matches what is currently the latest for the S3 on Fosi's website, Fosi S3 V1.0.274. The site does not show firmware downloads specifically for the S3 Lite.
My main problem with the S3 right now is the ARC implementation.
I don't like the fact that switching from ARC to another input source disconnects the TV. My LG C4 then switches the outpu to the built in speakers.
Also, my TV wakes up unnecessarily when the S3 is woken up and ARC was the last chosen input source. The S3 also turn off when turning off the TV. With WiiM devices this does not happen.
I hope that this is a limitation that can be fixed with software. At this moment i stopped using ARC altogether.
eARC is broken as was reported by several people in the review thread.
Besides that I wish the LED indicators for OPT in (green) and HDMI (cyan) would be more contrasting especially as they share the same space. Some sort of volume indication would also be nice.
That just sounds like normal HDMI CEC commands. On my C9 with eARC active and as many CEC controls off as possible, turning either on or off with the remote does not affect the other. The only thing that works on the LG remote is volume.
I wonder if the C4 has a different implementation?
I don't have any options to fine tune CEC, only on-off.
I would like to add another issue I have with the S3 - the standby function is not working properly, at least when streaming music through UPNP or Tidal Connect. I would need to make some further testing if it's one or the other or both.
Hours later after listening to some music the device still stays on.
