Dear Forum members,
Allow me to call on your knowledge due to a problem with Gain settings.
This is my setup:
I used to have a Hypex NC502MP based Amp, which unfortunately died after 7 yrs of intense usage.
It all ran fine with the DAC2 set at 4dBu / 1.2Vrms and the NC502MP with a fixed gain of 9.63dBu / 2.35Vrms / 25.6dB / 47 kΩ. (Normal Volume 10O'clock)
I bought the AUDIOPHONICS LPA-S600NCX presuming I could use the DAC2 and the PowerAmp both on Unbuffered. DAC2 on 24dBu/12.3Vrms and the NCX500 on bypass.
Theoretically the numbers looked like a perfect match to me, but I am not an expert.
In practice, it soon appeared that I needed to change the DAC2 attenuator (GAIN) to 2nd (14dBu) or even better to 3rd (4dBu).
Bypass on DAC2 leaves Volume below 9 o’clock for normal listening.
Position 2 Volume about 10-10.30 and pos.3 at about 11.30-12.
It doesn’t make sense to me.
Audiophonics (w?)couldn’t help me with this.
In pos.2 I also notice some Hiss now and then.
Any help with this case is highly appreciated.
This is my setup:
- Raspberry Pi 3B+ / PiCoreplayer (USB)
- Benchmark DAC2 (Pi by USB 2.0)
Gain settings:
dBu Vrms dB Ω
24 12.3 ? 60
14 4.0 ? 425
4 1.2 ? 135 - AUDIOPHONICS LPA-S600NCX (Hypex NCX500)
Gain settings:
dBu Vrms dB Ω
? 5.33 19 ?
? 2.67 25 ?
? 1.5 31 ?
? 1.2 33 ?
? 10 12.5 ? (Bypass/Unbuffered)
Hypex indicates 11.5dB /14.2Vrms unbuffered (why different?) and 1.5 kΩ unbuffered / 47 kΩ buffered. - Audiophysic Scorpio II
Nominal impedance: 4 ohms. Sensitivity: 91dB/W/m.
