I would assume most DACs outperform phono![]()
Hahaha. What I meant was in its "ranking", in that the DAC was in the top tiers and the phono was worse than an Art DJ Pre II or the Klipsch Powergate...
Yes, indeed. <https://www.project-audio.com/en/product/pre-box-ds2-digital/> I think this is a nice option, allowing it to fit in with gear from different eras. The clean design reminds me of the classic Yamaha stuff.It is available without the wood sides. Those cost extra!
It is a bit repetitive for sure. It does look like 1980's Yamaha gear as a nick said before in this thread or somewhere I can't find. It's timeless perhaps.Can I be the only one who thinks that Pro-Ject makes too many similar products?
We need to send more Panthers to Amir. As it is, we are a couple accidents away from everything getting a broken panther.I also think this doesn't deserve the golfing panther.
Phono is so-so and low impedance phones short...
Relax panther and recommendation, I agree, but golfing used to be harder to get.
But that's your panther, for sure.
Because it's twice the price and doesn't have multiple analog inputs or a phono headamp? You're talking about two products with very different feature sets and price levels.Why not get the minidsp shd which has a good dac as well, but can also do xover,dsp and dirac, not to mention streaming via volumio. The price is a bit higher but the features are worth it in the minidsp imho
Sorry I shipped it back already. I am very behind in testing these days....Dear Amirm, can you test phono with the MC and MM and also with subsonic filter for the SNR ? Thank you one more time for your work so important for audio community.
The phono ranking it not what it seems. Normally SINAD has a good mix of distortion+noise. So in one number, it gives you two major factor in electronic audio device performance. With phono stages at the input level I am using, SINAD is essentially measuring noise. Distortion as I showed is at -100 dB which is hugely better than the SINAD of 68 dB.I also think this doesn't deserve the golfing panther.
List price for shd is $1200 vs list price for DUT is 950-1050, not double. And the SHD has balanced and unbalanced analog in. The only thing missing is phono, which personally I dont care for.Because it's twice the price and doesn't have multiple analog inputs or a phono headamp? You're talking about two products with very different feature sets and price levels.
Transatlantic pricing differences - 849 € vs. 1 659,00 € both including tax. I read the SHD spec sheet as being a single input with both connector types - being switchable would be good. And I miscounted the analog inputs on the Project, so the inputs are a better match than I thought.List price for shd is $1200 vs list price for DUT is 950-1050, not double. And the SHD has balanced and unbalanced analog in. The only thing missing is phono, which personally I dont care for.
Do you mean the S2 or DS2? They are different ranges, the DS2 being much larger.Does anyone use the PRO-JECT Amp Box S2 as well or do you use a different power amp with the pre box?
Do you think PRO-JECT Amp Box S2 with Topping e30 would also make a good match?
The S2, the small one.Do you mean the S2 or DS2? They are different ranges, the DS2 being much larger.
Our main system is NAS > Raspberry Pi running Volumio > Pre Box S2 Digital > Linn Kolektor > Linn Klout > Linn Isobariks. We could use the Pre Box direct into the Klout but the Linn remote is so much nicer to use and the Kolektor simplifies usage with other sources. The matching Pro-Ject Amp Box S2 might be suitable for some efficient speakers but the specs don't seem too impressive.The S2, the small one.
