JeremyFife
Although 'headamp' makes me think of guitar pre-amps ... different use
Yeah - or it could mean microphone head amps. It's a bit ambiguous, it depends on the context - live, recording or replay.Although 'headamp' makes me think of guitar pre-amps ... different use
Possibly. It depends who you're talking to, possibly based on country, age or areas of experience, so you'll probably have to work it out from context. I've heard it used as a generic term for the first amp stage in the signal chain of an instrumentation system, possibly responsible for signal conditioning for the transducer. That fits the audio usage for a stand-alone phono stage, an active MC to MM step-up stage, or a mic preamp. I've not encountered separate amps for tape heads, but it would fit that too. The other main audio usage is for a headphone amp. I don't know if the guitar amp head comes from the same root.Is the term "headamp" synonymous with phono pre amp?
Hi, Amir, thank you for your great review, but with my knowledge, I can not understand why do you say a HPF is nice feature for this phono stage? Do you mean you dont want the signals under 20Hz?I was totally impressed by the implementation of RIAA equalization:
It is rare that we see such flat response regardless of price! Would have been nice to have a high pass filter though to deal with LP rumble and other low frequency noise but that would have increased the cost.
LPs don’t have much if any real content there other than the mechanical noise of the gear and the groove Think of it as a rumble filter.Hi, Amir, thank you for your great review, but with my knowledge, I can not understand why do you say a HPF is nice feature for this phono stage? Do you mean you dont want the signals under 20Hz?
You might find the conversation starting here <https://www.audiosciencereview.com/...o-mc-pro-phonostage-review.47139/post-1685555> of great interest.Hi, Amir, thank you for your great review, but with my knowledge, I can not understand why do you say a HPF is nice feature for this phono stage? Do you mean you dont want the signals under 20Hz?
Hi, it might be because the view includes noise in the calculation (?), but it does not clip at 20mV input at 15kHz. A friend of mine asked me to review his Phono Box and I found that noise floor is elevated relative to the low voltage input at high frequencies, and that causes the THD+N to go above -60dB.20mV input at 15kHz causes clip, that is ridiculously low!
A cartridge output is mainly at higher frequencies, and that's where the headamp needs the headroom.
Michael Fidler Spartan 5 (£150) quote 420mV @ 10kHz as opposed to about 27mV that this device can take.
Headroom is vital is headamps.
Highly unlikely that you will get better sound. Any slight improvement will be swamped by record-to-record variation.I have this box although not sure if there are any benefits upgrading to the CA Duo.
For my turntable I have a Clearaudio Concept paired with an AT33PTG/II ...
If I go for the duo will I see any difference in sq?
Why do you need HPF?Thanks
The lack of HPF is indeed too bad.
Those guys are producing a lot of those Phono preamps. We have quite a few measured here already.
This one is pretty good, especially for the money.
Prevent rumble.Why do you need HPF?
And subsonic speaker excitation due to record warps and tone arm oscillation.Prevent rumble.
There is no real signal down there anyway <https://www.audiosciencereview.com/...-vinyl-playback-discussion.34143/post-2336940>.Prevent rumble
There are different arguments here. One side is specific to phono amps, but the other applies to any source.Why do you need HPF?
Just to add that Mr Dernie has also been a highly regarded F1 engineer and designer!There are different arguments here. One side is specific to phono amps, but the other applies to any source.
The phono specific part is down to a few things. First the physics of the transducer, as @AudioSceptic points to, referencing a post by someone who used to work on such things at Garrard. The compliance of the cartridge and the combined mass of cartridge and effective mass of arm form a resonant system, usually around 10Hz if a suitable combination of arm and cartridge have been chosen, but could be higher or lower if they are less well matched - 15Hz is probably a practical upper limit. The resonance can be excited by warps or ripples in the record, among other things. Below ~2x the resonant frequency the cartridge output is inaccurate because of the resonance. Second, during the mastering process there is usually a high pass filter applied - they understand the physical limitations of the medium. Third, on a poorly engineered turntable there may be motor and/or bearing noise, predominantly at low frequency. Given all of these, there is no real signal below 20-30Hz - anything below that is noise not signal, so should be removed. Preferably this should be at source so it doesn't cause problems downstream. Summing left and right at low frequencies can help here too - warps excite the vertical resonance which will appear out of phase on left and right, so summing at low frequencies cancels this.
The more general argument is about frequencies below those that the system can reproduce causing problems (cone flap, excessive power, saturation of transformers etc.) It doesn't really matter whether the source is subsonic noise from phono, LFE from movies or music with a lot of very low content. The solution there is to high pass at a frequency suitable for the limiting part of the system, such as speaker or transformer. This is an argument for a filter in the preamp for all sources rather than just for phono.
From a system perspective you probably want only one filter to do this, rather than phono, preamp and power amp all doing it. That suggests each one should be switchable.
Correct, but his work at Garrard is more directly relevant for knowledge of transducer physics as it applies to turntables. That said, a lot of the underlying physics for dynamic systems is the same whether it's a turntable, a car, some machine in a factory, or a building vibrating in the wind or earthquake. And the equations parallel each other on the electrical and mechanical side, which is why we can use an electrical model to model the mechanical properties of a speaker, and a transformer to model the electromechanical part of the speaker motor. There are similar analogies in heat transfer, fluid flow etc.Just to add that Mr Dernie has also been a highly regarded F1 engineer and designer!
Yes, indeed (ICorrect, but his work at Garrard is more directly relevant for knowledge of transducer physics as it applies to turntables. That said, a lot of the underlying physics for dynamic systems is the same whether it's a turntable, a car, some machine in a factory, or a building vibrating in the wind or earthquake. And the equations parallel each other on the electrical and mechanical side, which is why we can use an electrical model to model the mechanical properties of a speaker, and a transformer to model the electromechanical part of the speaker motor. There are similar analogies in heat transfer, fluid flow etc.
What is the High-pass filter band? 80Hz, 120Hz or any other?Prevent rumble.
Usually subsonic: below 20Hz, typically 10HzWhat is the High-pass filter band? 80Hz, 120Hz or any other?
