@john61ct Then then the next step I suspect is to differentiate between the issue of building a single speaker, and the issue of making the whole system work coherently together. Since you are going multichannel, the latter is probably easiest to do by simply purchasing an AVR that have all of this built-in.
If you are going the active speaker route, simply using the same amplification/DSP modules for all channels will ensure similar latency for each channel (not that it really matters that much if you go the AVR route), and then you are only left with time aligning the individual drivers in each speaker, to the extent that you choose to care about that.
