- Thread Starter
- #21
Thanks so much for taking the time for such a detailed answer, will over time check out that calculator page (whooosh!)
If anyone can suggest more ELI5-level explanations written for noob laypeople, would be much appreciated!
Doesn't that contradict what I quoted in the previos post?
> Phase is frequency dependent, the delay will vary. "latency / distance" delays are a fixed delay for the whole signal, not frequency dependent.
OK that's a useful distinction.
How does "group delay" figure in there?
> 180 degrees out of phase means full cancellation.
OK, but what does "full cancellation" mean?
> For two drivers in one speaker, as you can see 0.25ms delay can be a problem.
"as you can see" is flattering me there.
> If you are running your woofer and tweeter on separate clocks it's going to sound insane. Even two clocks for two separate loudspeakers is likely to cause problems.
Why would a delay between drivers within a multi-way enclosure have any different effect than between separate boxen, if all are managed by the same active multichannel DSP?
Not my use case, but just to help me understand the principles...
phase when expressed as delay is frequency dependent
