Shorty
- Joined
- Sep 25, 2019
- Messages
- 254
- Likes
- 411
Here it is turned on at least 10 hours a day just like a television.
€0.75 spent per day on electricity.Holy Moses.
Quite correct. That is why LG is getting to extreme pricing on their 97" model - much more than current 115" mini LED class. If I recall correctly OLED was also supposed to build larger lines, but due to cost that was axed couple of times. I think it is safe to say that OLED gave up on the battle for larger formats aka 98" class and above. Competition in that area is quite overwhelming now.It has to do with manufacturing.
The battle now is between Korean and Chinese manufacturing.
Each new fab is a large capital cost that is spread over years of production, with oversupply dynamics. Fabs have to be built next to glass substrate factories. The glass substrates are classified by size in "Gen" - generation. Current OLED Gen 8.5 is 2200x2500mm. Current LCD Gen 10+ is 2840mm x 3370mm.
The substrate size controls the finished panel cut mix. The larger the finished panel, the greater probability of pixel defects. Then you need a sales channel to get some revenues from panels with pixel defects. The competition between LCD and OLED will go on for some time. Roll up OLED systems are a great solution to the big screen dominating the room problem, and shipping and installing big glass screens. Roll up will have its own quality and durability challenges to be solved.
I currently have a 52. Have had it since 2009. Still goes strong.
But considering 65. I typically sit about 7-8ft away... is 65 the right size? Also, speakers are a bit over 6.5ft apart, so the TV can't much more than 62 inches wide or so. I wouldn't want to spend more than $3k, because at the end of the day I don't watch too much TV.
Input welcome! I am no video expert.
I have installed TCL 98x955 and it was a project I underestimated and should have had 3 man crew instead of two of us.I recall the 'packaged' weight of some 100-inch class LCD TV's slightly exceeding 200 pounds. Select retailers like Costa tco have advertised installation is included with the price. I wonder when it will become practical for retailers to deliver and install a TV with a panel larger than 100 inches
I had a 37-inch Vizio that weighed enough that carrying handles are molded into the back panel. I recall seeing molded handles on the back panel of one 100-inch TV. I hope it becomes a more common feature.I have installed TCL 98x955 and it was a project I underestimated and should have had 3 man crew instead of two of us.
The weakest point in the installation was holding almost 80kg panel to put it on VESA wall mount. They have addressed that with 115" model that has the screw in handles on the sides. If they include that on future 98" models, that would be a piece of cake.
The packaging of the TCL 98x955 was sublime. Much better than the previous Sony 83" 90J OLED.
Damn, your exactly where I'm at. I can't fit in larger than my Samsung 85" and still have it centered between the L & R speakers.Ditto
The shape of my room and the placement of the Front L/R loudspeakers has determined that my display cannot exceed 85 inches in size
Which model TCL do you have ?The packaging of the TCL 98x955 was sublime. Much better than the previous Sony 83" 90J OLED.
That's EU model from late 2023, I guess it is US 2024 TCL flagship called QM8 or something? 5k nits and zones for 98". Not perfect but pretty good.Which model TCL do you have ?
Giant TV's are becoming irrelevant because they take up too much space.Projectors are becoming irrelevant because big TVs prices are falling
A large TV consumes twice as much as a UST projector, cannot be moved easily, does not have a lifespan of 30,000 hours.Must have a projector!
Pretty epic day!...
This evening it will be entirely used to watch the Champions League.
