Pressed steel speaker chassis vs cast or plastic
RoA
If I see a pressed steel chassis woofer I automatically assume cheap. If I pay good money for a speaker I want cast chassis high quality woofer. If I see the woofer screws go directly in to the wood I assume cheap. I want threaded inserts and nice bolts. If I pay good money for a speaker I want quality Xover parts not cheap stuff.
I know none will guarantee good sound quality but I just believe if I pay good money for a product I want some attention to detail, parts and sound quality commensurate with cost.
Am I that wrong? And yes I know, an LS3/5A uses a pressed steel chassis woofer too.
Am I that wrong?
Cheap doesn't mean poorly engineered. Good-looking and expensive material doesn't mean it's well-engineered either. You'll find plenty of counter-examples for both cases. Best to not look at the price, but let the objective data speak for itself.
I get that but if a speaker costs a considerable amount of money, measures and sounds good should cheap parts not matter?
I'd say, up to a point. There are also things like longevity, which also doesn't mean cheap is always worse, but sometimes it is. And you pay for the development cost as well. If a cheaply made stamped frame woofer gets the performance of a Purifi woofer, I think they would be entitled to ask a bit of extra money for it. It's al about value for money.
Yeah, "cheap" like this Peerless custom woofer:
Cast chassis tend to be made from aluminium, which acts to reduce certain types of distortion in the loudspeaker motor. The steel in pressed chassis increases that distortion. Plastic can sometimes be the best compromise, as it can easily be strong enough, if it's something like glass filled nylon, it's also cheap and doesn't increase distortion.
Another good counter example would be the Kii Threes stamped steel Peerless/Tymphany woofers. Implementation is king.
12 Euro drivers (the Peerless SBS-160F35AL01-04 used as bass driver is around that price too if you buy 500+ units).
You see, to me that is not acceptable in a $14'000 product let alone that Kii didn't even develop their own drivers.
If you are happy to pay that for something that uses some of the cheapest drivers around, good for you.
Nobody said this... Looking at the distortion figures of the bass of the Kii 3, it isn't particularly good, especially for 4 woofers per speaker. So it isn't really very good value in this regard.
How much should a driver of a speaker with retail price of, say, €500 cost in BOM?
Driver of a cheap ELAC. I would still not be happy with wood screws but that it excusable in a product such as this. I have no idea how this measures but I'd much rather know that my Kii Three had something like this inside.
Looks plastic to me.
Taking your Neumann's as an example, they use cheap drivers in an active pair of speakers retailing for around that price for one speaker but at least you get (cheap) amplifiers and DSP with it.
Yes or really expensive drivers in really poorly measuring loudspeaker designs, a terrible waste.
You are correct that none of these guarantee good sound quality. And the LS3/5A sound bad for reasons that have nothing to do with the woofer chassis.
Good grief, are you just arguing for high prices? These are great sounding speakers. And very reasonably priced. Any change in BOM cost will translate to nearly 10x price increase. The majority of the audio industry is infected with compulsive FOMO and FUD regarding exotic materials, what we need is better acoustic engineering not fancy driver chassis.
