PreSonus Sceptre S6 Monitor Review
Rate this speaker/Monitor:
    Votes: 88 43.1%
    Votes: 105 51.5%
    Votes: 10 4.9%
    Votes: 1 0.5%
This is a review, detailed measurements, EQ and listening tests of PreSonus Sceptre S6 studio monitor (powered active speaker). It is on kind loan from a member and costs US $899 each.
PreSonus Sceptre S6 CoActual 2-Way Studio Monitor Active DSP Power Speaker Review.jpg
I must say, the "duck bill" shaped waveguide on the coaxial tweeter is the first one for me. It is doubly strange since it almost completely covers the 6 inch woofer. I worry about reflections back and forth from the woofer if the crossover is high enough to allow it. The slot port is larger than usual as is the overall cabinet which feels quite substantial for a monitor with a 6 inch driver.
This is an active DSP speaker with bi-amplification.
Searching online, I see a review dating back to 2014 so the design has been around for more than a decade now. It is stocked and sold so still current.
I very much like the usability of controls in the back:
PreSonus Sceptre S6 CoActual 2-Way Studio Monitor Active DSP Power Speaker back panel gain Rev...jpg
There are LEDs that light to tell you the setting. I left the all as "Linear" and adjusted the Level for minimum (it was quite sensitive). Measurement axis was center of the tweeter.
PreSonus Sceptre S6 Monitor Measurements
As usual, we start with our suite of anechoic frequency response measurements performed on Klippel NFS:
PreSonus Sceptre S6 CoActual 2-Way Studio Monitor Active DSP Power Speaker Anechoic CEA-2034 F...png
Story starts really good with deep and flat bass extension. We then have some disturbances around 1 kHz which are likely caused by cabinet. But then we see clear signs of reflection interference from 2 to almost 10 kHz, caused by that large waveguide. The wavelength has to get small enough relative to the distance of the waveguide for this to happen. It peaks around 4 kHz. This will be angle dependent as we see here:
Notice how at -30 degree, that peak becomes a dip. This is reflected in our very messy early reflections:
PreSonus Sceptre S6 CoActual 2-Way Studio Monitor Active DSP Power Speaker early window Anecho...png
Resulting in the same for our predicted in-room response:
PreSonus Sceptre S6 CoActual 2-Way Studio Monitor Active DSP Power Speaker predicted in-room C...png
There is also some elevation in the treble which I am assuming can be partially corrected using the setting in the back.
We can see the manifestation of this issue in our directivity measurements:
PreSonus Sceptre S6 CoActual 2-Way Studio Monitor Active DSP Power Speaker horizontal beam width.png
PreSonus Sceptre S6 CoActual 2-Way Studio Monitor Active DSP Power Speaker horizontal directiv...png
Instead of the waveguide giving us controlled directivity, it gives us narrow and uneven dispersion.
Vertical response is even narrower, which again doesn't do what coaxial drivers normally deliver:
PreSonus Sceptre S6 CoActual 2-Way Studio Monitor Active DSP Power Speaker vertical directivit...png
Near-field response shows port/cabinet resonances:
PreSonus Sceptre S6 CoActual 2-Way Studio Monitor Active DSP Power Speaker near-field Frequenc...png
And same interference pattern in lower treble.
I was surprised to hear distinct low frequency distortion regardless of level. Measurements back this:
PreSonus Sceptre S6 CoActual 2-Way Studio Monitor Active DSP Power Speaker Distortion measurem...png
The woofer is very uncomfortable being cross so high, with very high level of distortion in multiple regions. Tweeter is kind of OK but close to end of its range, it too gets out of control with very high level of distortion.
Here is my standard distortion graphs:
PreSonus Sceptre S6 CoActual 2-Way Studio Monitor Active DSP Power Speaker Distortion THD perc...png
PreSonus Sceptre S6 CoActual 2-Way Studio Monitor Active DSP Power Speaker Distortion THD meas...png
CSD/waterfall as expected shows many resonances:
PreSonus Sceptre S6 CoActual 2-Way Studio Monitor Active DSP Power Speaker CSD Waterfall Measu...png
Here is the step response which is rather uneven:
PreSonus Sceptre S6 CoActual 2-Way Studio Monitor Active DSP Power Speaker Step Function measu...png
PreSounus Sceptre S6 Listening Tests and Equalization
The first impression is the warm and solid bass response. Research shows that bass is responsible for 30% of our preference and this speaker backs that. I could not immediately detect faults until I created a couple of narrow filters to pull the peaks in the interference region:
PreSonus Sceptre S6 CoActual 2-Way Studio Monitor Active DSP Power Speaker equalization parame...png
The difference as noticeable but subtle. It simply removed some of the brightness. It is not clear that it would win in any blind test but it was my preference to have them there.
Sub-bass at low playback levels was handled well in the way the speaker simply filtered them out. We could predict this from the sharp drop off in bass frequency response.
Crank up the levels though, with just about any content and you start to hear distortion in the form of warbling and weird artifacts in lower frequencies. Keep cranking it up and it gets worse and worse -- again just like what the measurements predicted. Granted, there is decent volume there before this gets out of hand and with two speakers, you may be able to avoid most of its impact.
Noter that there is tweeter hiss that is audible starting from 1 meter/3+ feet in my space that has a bit of computer fan noise.
When I look at a speaker, I always imagine what path a light source would take if it were coming from the drivers. Here, it is easy to imagine that it would start to bounce from the waveguide and go back and forth. At the right frequency, you get constructive addition or subtraction, causing the waviness we see in the response. This could have been partially mitigated by crossing the woofer lower. This would have also lowered the distortion coming out of that 6 inch driver. Then again, I am not sure what the large waveguide is doing for us. Yes, it allows the company to advertise "CoActual" response and that has marketing value. But objectively it didn't deliver on any promise from such an architecture.
Overall, there are some good ideas here. The subjective performance is actually better than what the measurements show -- if you keep levels reasonable. Alas, at $900 there is now stiff competition from much better executed designs.
Putting it all together, I can't recommend the PreSonus Sceptre S6 monitor.
@amirm , the near-field graph doesn't show the tweeter response. Copy and paste mistake?
I believe this has a compression driver for the tweeter, which would explain the high H2.
I wonder why would someone buy it when for less money you can get an in all disciplines better performing 3-way Kali coaxial instead. Ok, 10 years ago those didn't exist, so possibly its a relict of its time.
I don't think this is better than the Adam T8V studio monitors at 1/4 the price. I'm voting poor.
That's 2 poor measuring speakers from Presonus in a row. The previous poor measuring speaker which was at least really cheap could maybe be forgiven but then we see this one and it starts to look pretty bad.
I can't isolate the tweeter since it is inside the woofer. So you get everything sans the port.
Reactions: Pio
I've never seen an estimated in-room response that is so....wobbly?
Wow, this box is simply a real professional "if your mix sounds good with this speaker, it sounds good on every speaker" product. :)
Not only the unlucky waveguide, box width, overall distortion and interference problems. Even the impuls response shows inverted drivers. You won't do this, specially with the potential of a active DSP speaker.
It is, but at the same time, have to wonder, if its really "That" bad in reality?
I mean the variations are all within 5db, and yeah it looks bad, but without buying these just curious if it would be audible as horrible, or just a bit flawed??
Goes to show how nontrivial the construction of a 2-way coax system is. Nubert demonstrated the effect of cone excursion on tweeter response with a 5 inch Seas coax without any Waveguide:
Outwardly excursed cone:
Inwardly excursed cone:
Source:
So Just +-2,5mm of cone excursion can cause big amplitude differences.
Makes one really appreciate KEFs tangerine waveguide, that avoids both the shortfalls of the Presonus and the Seas coaxes:
