Alchemist_
- Joined
- Mar 7, 2020
- Messages
- 165
- Likes
- 27
There is a real lack of information like this.
I had to buy them almost blindly.
I own the E8XTs.
They don't hiss, hum, or make popping noises.
And I like their sound.
The Studio 8 is the updated model.
But they are completely different monitors.
I was pleasantly surprised.
They also don't hiss, hum, or pop.
The cabinet is taller.
The bass reflex port seems slightly larger.
There's a new woofer.
The tweeter might be new, too.
New front panel.
New electronics (the XT8 picks up some interference in one room, whereas the Studio 8 doesn't have that problem).
There's an audible relay click now when you turn them on.
Adjusting the knobs is easier now.
There are markings on the panel.
As for the sound—the XT8 sounds good, but the Studio 8 sounds even better.
The Studio 8s sound more balanced. The frequency response seems even flatter now. The bass goes deeper! The high end is smoother and of higher quality.
And most importantly, the midrange—it’s much more refined.
The sound is more detailed.
Spatial imaging is much better.
Excellent instrument separation.
You should always listen to speakers before buying them.
These are definitely worth a listen.
I own the E8XTs.
New front panel.
