Has anyone experience with it? https://www.presonus.com/products/AudioBox-Go/tech-specs
I want simple DAC for listening music for my Adam T8V speakers. I already have SoundBlaster X-FI HD with unbalanced RCA output only. It works with laptop, but when I connect it to PC there is typical 50 Hz hum I can't get rid of. I just want to connect it properly with balanced TRS/XLR cables.
I found a review https://www.recordingbase.com/presonus-audiobox-go-review/, but I think the author has misinterpreted the technical specs. He states "But, the S/N Ratio (signal to noise ratio) is 90 dB which is not good as other audio interfaces in the same price range.", but the 90 dB SNR is for Headphone Output, not the Line Output, according to the specs.
I am deciding between this one and Behringer UMC22. Or should I rather go for Focusrite Scarlett Solo 3rd Gen?
I want balanced output, heaphones jack on the front panel and no driver installation to get it work in Windows 10. Thank you.
