Pre-amps with Loudness - OSD Pre-1 ?
john61ct
Most of my source-switchers and volume controls are analog-only, which is my preference. I am also frugal, some months actually poor 8-(
I like having physical tone controls, and miss the old variable loudness curve feature, ideally automatically coupled with the volume level, but I guess that requires a DSP these days?
I've looked at Schiit's offerings but they haven't done Loudness, (EDIT I was wrong YAY 8-)
and yes I am aware of why so many Loudness circuits suck, please don't tell me "just say no"...
I've gone down the research rabbit hole on Wiim Ultra, but despite its incredible value and array of features, it seems its Loudness preset is not all that great?
I also want to use it for room correction, and it seems that you can't have both without manual guesstimating? All feedback welcome on those issues...
I have found OSD's Pre-1, which also offers "tape monitor" in-out looping, another feature I wish was more common on modern pre-amp gear.
Any feedback on the likelihood of that unit's "clean transparent" SQ ?
Any better suggestions, short of renovating ancient gear? No tubes please!
TIA
Specs from OSD:
signal-to-noise ratio:
>80 dB line
>70dB phono
>50dB mic
total harmonic distortion
>0.2% line
>0.4% phono
>0.4% mic
are those Line specs horrible? (if true)
Hi
On the Amazon page you linked us to :
Caveat emptor
Peace
FWIW you can get Loudness control with Schiit's new products like Mimir (using their Forkbeard digital control module/app, currently iOS only)
NOICE! I don't need "yet another DAC" but I guess they just come free in so many boxen like the temporary tattoos in a box of Cracker Jacks 8-)
And I think Schiit's SQ and loudness implementation is likely to be at least "pretty good"
No "tape loop" monitoring though 8-(
Thanks for the pointer!
Eww, iFruit only 8-O
maybe my teen daughter will lend me one of her old ones
Chase RLC-1 "remote line controller"
loudness compensation is automatic, increases as volume lowered
Seems ideal? and they go for cheap! please, feedback from any members familiar
Mimir's Fletcher-Munson loudness EQ implementation (actually, Forkbeard's) is not just
variable, increases automatically as volume level is lowered (and v/v ofc), but is also
scalable, you can manually dial their algo back if the default "intensity" is greater than what you prefer
Jason: "I don't think that's EVER been done before, in analog or digital."
A Good Thing™ since often in such tweaking, less is more, subtlety the key
I wish Wiim Ultra had a "Fletcher-Munson loudness EQ" feature like Schiit Mimir, automatically varied with the volume control
and a **separate** control panel where the user could
scale the implementation of the curve to be more vs less "intense"
set the volume control level "reference point" above which the feature stops affecting the EQ
and just toggle the whole feature on and off
These settings would be a **separate** overlay in relation to other EQ features so largely "set and forget" unless the user's preferences (or hearing) changes, or of course system altered.
Found an Adcom GFP 555 (pre-amp not power) which has a simple loudness "Contour" toggle. Also balance, bass / treble knobs, mono, hi/lo filter buttons, decent phono stage, integrated HPamp...
Two different RCA analog outputs, one with capacitors in the chain and another bypass "Lab" output that is DC coupled for purists
Two separate input switchers, one for Listening, the other "recording" for external signal processing loop inputs
each offer FIVE choices of analog inputs, not counting phono
THREE external processing loops, two switched / bypassable + one marked "Signal Processor" unswitched full-time but via bridging inserts.
Unknown if the "Lab" RCA output bypasses that last full-time loop or not, presumably does disable the tone-related front controls.
Also unknown if the GFP-555's loudness contour is automatic-variable or not, will test it against say Chase RLC-1, maybe Schiit Mimir for use on the full-time loop as remote volume control.
Then maybe put an OG GEQ or Wiim Ultra / other DSP EQ on to a switched loop for room correction EQ, so can disable for headphone use
If Mimir is not used for volume control + loudness then putting it on the second switched loop could PEQ differently for headphones, and/or act as remote ad-hoc-adjustable PEQ tone controls
with more applicability than the GFP-555's, which only affect 40hz and 15khz
I think safe to say blows the Pre-1 out of the water...
yes likely need to renew capacitors
My posts here and here on the thread "Tone control" would be of your reference and interest, I assume.
I have selected three "finished" preamps' Loudness Compensation designs to test, plus have high hopes for the DSPi project in future.
All vary automatically with volume level, but only to the extent volume level is attenuated at that same preamp device.
One is RLC-1 from Chase Technologies, with which LC is both non-adjustable - I suspect may be "too strong" intensity - and cannot even be defeated without being disconnected, or say put within the tape loop of #2
which is Adcom GFP-555 - this has (I believe) a gentler slope, LF boost only and ofc a bypass / enable toggle control.
The third will be Schiit's new "Eitr 2" with the Forkbeard module, all-digital and very flexible LC controls.
I will have all three concurrently available, switchable from Wiim Ultra outputs for easy AB comparison testing and analysis using REW and other tools.
If the RLC-1 "fails" it may get tested to be re-purposed for the LF / sub(s group), serve as a relative level control + tunable "bass boost",
and it also has 4-ch output from OG Quad days so can act as a Front/Back fader control (!!)
Device ordering logic
I believe that is on their roadmap, but no idea when it might happen.
Some Yamaha amplifiers have a variable loudness - like the A-S501 and A-S701.
Yes, but I prefer separate power amps, so let's keep this thread to line level units.
Unless discussing the tech details of "unusually good" implementations.
What I now look for in LC implementations:
Automatic varying by volume, prefer if user can calibrate 0db point where LC gets disabled
ideally auto sensing level controlled upstream, but it seems does not exist, must adjust volume in the same unit or via signal from direct host as with USB.
Intensity of the curve can be adjusted
ideally completely different curves selected.
not sure if this last exists.
All of this can be implemented in theory via DSP including by Wiim
But my approach currently is "DSP only as needed", for each old-school signal processing function start with analog, even if passive.
Others will have different preferences / approaches.
RLC-1 and GFP-555 are both analog RCA only - any reco's for a cheap & cheerful but reliable manual switcher in black?
The Onkyo P-80 has also a variable loudness. It's called Fidelity IQ. But I think if you want a proper, or just the best loudness implementation, there is no way around the RME Adi-2 DAC FS.
