Poweramp with bit-perfect options
Ruediger
Player software Poweramp now features comprehensive bit-perfect options. Enabled in beta 1028, which users can download as apk already.
A huge step away from "resample anything" to what other players like UAPP etc are doing. Which do not have that nice GUI and intuitive, detailed config.
I can recommend to try it out for DAP or mobile alike. The audio info display of how the signal is processed (or not) through every step on a device is especially helpful, now with bit-perfect and 64-bit path unlocked.
Is this for external DAC, or internal, or both?
Can it play files from my DLNA NAS or PC?
Could you clarify the wording “a huge step away from ‘resample anything’ to what other players like UAPP etc. are doing”? As written, it sounds as though UAPP might be included among players that resample everything, which I assume is not what you mean.
My understanding is that UAPP has supported bit-perfect playback since its inception, using its own audio stack to bypass Android’s normal audio path and SRC. When no DSP or other processing is applied, the output is mathematically identical to the source, which is precisely what “bit-perfect” means.
So are you saying that Poweramp is now adopting a bit-perfect approach comparable to what UAPP has offered all along, or am I misunderstanding the sentence?
Yes, it's more like what UAPP does now. This behaviour wasn't there before - precisely to follow the content's bitrate/depth and not resample. It's optional and was the top wished for feature by users by vote.
The audio path could be chosen (per output device) before, f.e. hi-res. But the options to control what it does or does not with the content are new.
Poweramp can play streams from network, but doesn't do smb or upnp.
So how does it access windows network shares without SMB?
I see no samba client in this one. My scope of usage with Poweramp/UAPP/Neutron is local media on DAP/Android. To have the media (to go) an app syncs my stuff with the device sdcard.
I'm probably in a minority, but find it useful to have FB2K able to use its built in SMB to access music on my NAS or PC as if the files were local. I'm cheap, so I don't want to put 1 or 2 TB micro-SD in my phone to have copies of my music files!
I do the same at home, work, PC, laptop etc.
Also many players have samba clients. UAPP and Neutron f.e., but some are more focused on local playback.
Can't say I have wireless access for the DAP all the time, local storage is a must. Not only on the road, also around the house, gardens, other buildings. Large area.
For the mobile it's mainly Android Auto that makes me have the media on it.
One thing to consider with wireless coverage is roaming. I have yet to see a mobile that does not create problems here and there with audio playback while switching access points. It shouldn't, but it's not only about the mobile OS, also the client and player.
I don't get the obsession with 'bit-perfect', the benefit of DSP for room/speaker/headphone correction are well documented. DSP changes the bits, so nothing going through DSP will be 'bit-perfect'.
I've used PowerAmp for many years as the interface is much better than UAPP (I own both). I synchronize my whole FLAC library (+32K files, ~1.5TB) to my phone (Pixel 10 Pro XL 512GB) using MusicBee and convert everything to high quality Opus on the fly - the library takes up around 320GB on the phone.
Yeah I don't get it either. DSP to do EQ and even something as simple as a volume control is of much more importance. And do people actually know they even hear what that "pesky" resampling is doing or is it just that bias kicking in as usual?
I think bit-perfect is, in most cases on a phone, inaudible. At least I can't tell that FB2K is up or down-sampling to 48k on Android (even with a decent external DAC).
Having said that, I do like the basic "honesty" if you will, of being able to play files back in the original form. On windows, I always play back in exclusive mode using FB2K, which at least means I get zero system sounds when listening to music. This is a feature I'd like in the Android FB2K too, but it's not quite enough to make me switch. I'd also like the Windows version to have a 64-bit UPnP plugin to play from my DLNA NAS (only an old 32b plugin does this currently). My point is really that there are a lot of functional inconsistencies between media players on various OS, and it's a bit of a minefield - if someone pulled together a free player with a good GUI and all the best features, they'd be onto a winner. (Make note, the Pleez developers in another thread)
When I see the whole signal path on my mobile (not a DAP), which Poweramp displays so nicely and puts of "score" in the end, I agree that this is rather unimportant on a phone.
More a thing for audio players with different capabilities.
As for DSP, not everyone uses it or not for every output. Volume control could be hardware?
If done properly, resampling is inaudible on anything...
  • Transducer Distortion:
    • Studio Monitors/Speakers: 0.1% to over 5% THD (Total Harmonic Distortion), depending on frequency (worse in bass) and volume.
    • Headphones: 0.05% to 1% THD.
    • Physical transducers are the weakest link in any audio signal chain.
  • Resampling Distortion:
    • Modern Sample Rate Conversion (SRC): Better than -140 dB to -170 dB (equivalent to less than 0.00001% THD).
    • This is buried deep below the noise floor of 24-bit digital audio and is entirely imperceptible to human ears.
The first clear evidence I can find for UAPP explicitly adding a “bit-perfect” option is version 3.1.5, released in September 2016, so that’s almost 10 years ago. I’d therefore qualify your statement that “this behaviour wasn’t there before.” While you’re right that bit-perfect wasn’t part of UAPP from the very beginning, it has nevertheless been a core UAPP capability for almost a decade.
That said, I’m not suggesting that bit-perfect playback is necessarily the be-all and end-all. UAPP’s UI is, frankly, near atrocious, and the app itself can sometimes be quirky and unpredictable, particularly in the way it handles its various playback and output modes.
But it is an unusually comprehensive audio front end: it supports an impressive range of sources and endpoints, from local files, Qobuz and Tidal streams, SMB network shares and UPnP/DLNA servers to Chromecast, all within the same application, while providing its own audio stack and direct output path where appropriate.
That combination of broad source integration and low-level control over the audio pipeline is what keeps me coming back to it.
We have a slight misunderstanding. I acknowledge UAPP has all this since longer than I know the app. And just mention the changes in Poweramp, which had a different approach and just added the whole bit-perfect topic.
I find it particularly noteworthy because the Poweramp GUI is superior to me. Better than UAPP. And much better than Neutron, which is a cruel joke to me.
