Power the raspberry pi through the SMPS1200A400
  • Thread starter Thread starter Deleted member 37168
  • Start date Start date
D
Guest
Is it possible to power a rasperry pi using a SMPS1200A400? I realize it's not plug and play.
I ask because I want to use the same power source in my setup and build it all together in one setup.
Purify EVAL1
smps1200a400
SMSL SU-8s
Raspberry PI4
So what I want is suggestions to be able to power my raspberry via the smps1200a400
Not worth the effort. Closest supply voltage is Vaux and it is 22 volts at 500 mA.
Can power the rpi better and more readily with a usb adapter.
I would not recommend the effort either, but you can try with a DC-DC buck converter that support 24V to 5V. Just search for "buck converter 24v to 5v".
