Hi all, mechanical engineer here building a speaker and I am hoping to get some clarification on my design. Currently, my speaker plays music, but there are a few issues...
Overview of my active, powered speaker build components:
1. Peerless by Tymphany SDS-P830657
2. Dayton Audio ND25FW-4 1" Tweeter
3. LRS 150 24 PSU
4. XKitz LR 2 Way Active Crossover
5. Amp, Wondom AA-AB32174
My questions:
1. You can see this in the attached video file, but there is a horrible whine that plays when the speaker turns on. I powered the system using a desktop power supply at work, and there was no whine at all, so I am sure it's coming from the power supply. Im hoping to get some EE explanation on where this comes from and what I can look for in other power supplies to fix this problem.
2. Currently, I am just feeding in a RCA audio source from my record player. There is no volume control on the speaker itself, but I would like to add that. Can I just take a Potentiometer and smack it in-between the RCA input and the RCA input to the crossover? I have the hardware to do that, I just wasn't sure if that's valid or if it will introduce some similar noise issues.
Video Link
Looking forward to chatting about this!
Edits:
Added Amplifier to component list
Is the XKitz LR 2 Way Active Crossover also being powered by the Meanwell? I see two sets of cables coming out from the PSU.
Care must be taken when powering multiple analogue equipment from the same SMPS, especially when they have a different "mid point" voltage.
Without going into details and without spending time troubleshooting, the solution is to get a power supply that works with this application.
Alternatively you can just power the XKitz with its own power supply just like what happens when you buy separate products, and see if the problem goes away.
Add: Instead of connecting the XKitz directly to the Meanwell, you can also try to tap the voltage from the PCB of the amp, often such amp modules will have locations for you to daisy chain the power cabling which is useful for situations like this. It won't solve the fundamental problem behind, but if you're lucky you may reduce the noise to the same level as a soundcard in a computer.
This module reminds me of Sure boards for some reason. I used the included barrel cable to connect to the PSU, which leaves the screw terminals available for other stuff.
