>>bump<< Sorry to resurrect this, but I thought this might justify it.
As of late I've been chasing hum (another story) leading to some ASR discussions about whether external power supplies, wall-warts, etc. “matter” for DACs, streamers or anything else. Rather than debate mechanisms in the abstract, I did a simple before/after measurement exercise in my own system and wanted to share the results.
Setup:
- Same room, same mic position
- Same electronics, all turned on, same DAC / streamer / DSP chain
- Measurements taken with REW, identical settings. It's quiet room.
- No DSP, EQ, or filtering differences between runs (but wouldn't matter cause there's nothing playing except any measurable system noise)
- Conditions:
1. Wall warts on separate circuit feeding a DAC (Modius e), DSP processor (MiniDSP Studio + remote control dongle and 2 ethernet switchs)
2. Wall warts were then all replaced with a Cioks DC7
Conditions:
1. Stock wall-warts on a separate circuit feeding:
- DAC (Modius E)
- DSP processor
- (MiniDSP SHD Studio + remote dongle)
- Two Ethernet switches
2. All wall-warts replaced with a single
Cioks DC7 powering the same devices
Results:
Attached are two plots:
- Baseline noise floor (original power configuration)
2. Noise floor after power changes
What’s interesting is not any single spike, but the
broadband reduction:
- Several dB lower noise floor from roughly 1kHz up through a 10kHz. This was repeatable.
- Clear reduction in low-frequency hash and mains-related components
- No changes above the system’s inherent noise limit
To be clear, I’m
not claiming this proves some audibility improvement, “sound quality,” or that power supplies alter digital bits, blacker blackness, holographic sparkle, etc, etc. What it
does show is that:
- Power and grounding choices can measurably change the electrical / acoustic noise environment
- Some wall-wart / shared-circuit configurations are objectively noisier than others
- These effects are can be visible and easily measured without exotic test setups or equipment
If someone wants to argue
why this happens (ground impedance, leakage currents, SMPS common-mode noise, etc.), great — that’s a useful discussion. But at minimum, this seems to move the conversation from “purely theoretical” to “measurable under ordinary conditions.” YMMV but that's what I got.
Cheers,
