Power mains,cable C5,mickey mouse
gasolin75
Denmark
I like to upgrade cables and feet for my hifi stuff
I have a wiim vibelink and it uses mickey mouse c5 plugs for the power
I know supra makes some very reasonable power cable, that price wise match what i think most people would pay to upgrade power cable,mains on a wiim vibelink
Problems is, they don't make any cable with c5,mickey mouse plugs, other brands that makes power cable for not alot of money like Monosaudio, also don't make any with c5,mickey mouse plug and schuko at the other end
It's not about if they make a difference or sound better
It's about why they don't make any and if there is any out there for 50 euros or a little more
Even when some don't have a an expensive system they stille wanna upgrade things like power cable,mains as some do with big,expensive systems
If people didn't buy expensive power cable they wouldn't make them, if you can afford 1000 euros pr meter speaker cable you might also be able to afford to upgrade power cable,mains
I have heard chord is comming with a c5 cable but don't know anything about it other than it's comming his year
Don't make the thread about, it doesn't matter, no difference,waste of money
The real reason no sellers exist is because there is no seller capable of making one.
Notice all the "audiophile power cables" are made using hand-assembled connectors. C13 connectors, those are easy to find, audiophile or not. C5 connectors on the other hand, non-existent.
This means C5 cables would need to be made from the factory. Which results in the current situation.
It is difficult to not do that considering the entire industry is about doing that. I will stop my explanation at the last point above since any further will require doing that.
Hmm... what was the thread about again?
Out of stock most places and more than 1 meter it's like 120 euros
With amps like a nad D3020 and wiim vibelink, there are a few units with that type
As mentioned it can be the same as those with a big expensive system that wanna upgrade power cable
They just don't wanna buy something expensive or else they money could have give them a much better amp (even with stock power cable)
The difference is the price of there system, not if they do or do not want to upgrade,tweak,fine tune (call it what ever you like) there system with cables
Thought i had bought the audioquest with c5 but it was with c13 plug
Is there anything i can buy as an upgrade from europe that isn't the price of the audioquest cable and where i can get it in mabye 2 days, first i have to either sell it or ship it back and get the right cable with c5 plug = pay for shipping it back and again shipping for the right cable with my "wrong" cable
Not even used i could find anything better than the stock 10 euro C5 cable
I wanna skip my usb converter + upgrade my power cable for my vibelink and i have all upgraded,optimized what i can for my hifi
only think left is room (another story)
