restorer-john
I finally got my 300W test resistors. I can wire this thing for 8, 6, 4 and 3 ohms load, although I mostly will test 3 and 4 ohms I guess.
And, you can use it for heating your room in winter.
Not even close.I was thinking of a cheap way to measure my AVR power output, at minimum impedance, with speakers connected and if it goes into clipping at the listening level I use with movies, but without hearing protection from high SPL.
If I connect my AVR through a kill-a-watt meter and look at the idle power draw and then I play a 1 or 2 Hz full scale sine wave (with bass management disabled) and raise the volume slowly in 3dB steps, that should give me a rough idea, no?
Some off-the-cuff thoughts:I was thinking of a cheap way to measure my AVR power output, at minimum impedance, with speakers connected and if it goes into clipping at the listening level I use with movies, but without hearing protection from high SPL.
I already measured max unclipped Vrms of my AVR with a multimeter, but I don't know if that output does not drop when speakers are connected.Convert to watts using an impedance plot for your speaker or using a 1 kHz tone and the nominal impedance (which is usually measured at 1 kHz): P = V^2/R (where R is the magnitude of the impedance).
Well, it will drop, even if only a tiny amount but could be more. If you know the impedance of your speakers, buy a high-wattage load resistor of the right value, and measure using that to see how much it drops. Then you can use that number with the sensitivity of your speakers and distance from them to estimate your maximum SPL.I already measured max unclipped Vrms of my AVR with a multimeter, but I don't know if that output does not drop when speakers are connected.
I'm sorry I'm late, but I would have suggested some sort of active cooling to the dummy load. Like an floor standing fan and/or you could even dip one end of the cooling plate in water. With that much heat even heat radiation should be considered. The resistance of a resistor usually climbs when its temperature rises, and with such high temperature that might affect the results.This is a wrap for now. I've got :
- some interesting results
- one destroyed Hypex NC502MP
- burn scars on my fingers from touching the dummy load, that reached in excess of 150 degrees Celsius at the surface ......
As I have mentioned at some other point, somewhere or another on ASR -- an oil bath is the classic way to do it.I'm sorry I'm late, but I would have suggested some sort of active cooling to the dummy load. Like an floor standing fan and/or you could even dip one end of the cooling plate in water. With that much heat even heat radiation should be considered. The resistance of a resistor usually climbs when its temperature rises, and with such high temperature that might affect the results.
I had a power meter and Cantenna for years (had a D-104 mic instead of Heathkit), but sold them with my station when we moved and I left everything behind. Should have kept the Cantenna; I had made a second top for it with five-way binding posts to a parallel array of non-inductive power resistors to create an 8-ohm load. I have some of my old gear in boxes, somewhere. I kept thinking I'd renew my HAM license but never got around to it; didn't need another expensive hobby for which I had no time. Another regret is not turning in my 2nd class radiotelephone license; I passed the test but the 1st class exam was scheduled in a few weeks, so I held on to the paperwork so I could go 1st class. Never happened.As I have mentioned at some other point, somewhere or another on ASR -- an oil bath is the classic way to do it.
cf. the long-running Heathkit "Cantenna" kit (for amateur radio, but an AF version would be a pretty straightforward hack).
source: https://www.worldradiohistory.com/Archive-Catalogs/Consumer/Heathkit-1974-03.pdf
Oooooo, bad boy! No lollipop for you!I have always wanted a D-104. I do like the sound of those suckers*.
I would be too! Of course, I am still paying IEEE dues, and haven't really used the journals for several years. Hard to give it up. Might need it if I give some lectures at the local university, which is what I thought last year...My father had a First Class FCC license, which he kept current for long after he actually stopped using it professionally.
He was very proud of it.![]()
YES! Doing any longer duration power testing it is really incumbent on the tester to, at the test conclusion, quickly disconnect the load and measure the resistance to see if it has heated. This means testers really need a higher power rating than the test and lots of heatsinking and liquid nitrogen. Well, maybe a fan at least.I would have suggested some sort of active cooling to the dummy load. Like an floor standing fan and/or you could even dip one end of the cooling plate in water. With that much heat even heat radiation should be considered. The resistance of a resistor usually climbs when its temperature rises, and with such high temperature that might affect the results.
All the tests I have seen is at the 2 x 300-350W ballpark for continuous.Ive whizzed over this thread but have not been able to find the information I'm looking for. What is the continuous rating of the 1200AS2 both channels driven at 4 ohms?
Thanks, I'm considering using the 1200AS2 to drive 4 ohm stereo speakers that will be crossed over to a powered sub at 80-100hz.All the tests I have seen is at the 2 x 300-350W ballpark for continuous.
The test done here was for 60 sec and showed about 600W for one channel (my opinion is that's how they must used, I have them that way)
They do hit kW at bursts but that's close to useless in my book.
Cooling must be adequate of course, that goes without saying, same as any high power amp.
It might be a good idea to wait, they may updated it to Conductor technology.Thanks, I'm considering using the 1200AS2 to drive 4 ohm stereo speakers that will be crossed over to a powered sub at 80-100hz.
It depends on cooling and music material.For the 1200AS2, Vintage flanker mentioned a continuous rating of 400w to 500w at 8 ohms. Hence, I'm guessing it will sit at about 500w to 600w continues at 4 ohms all channels driven above 80Hz.
