Which of the current peak power rating methods do you think comes closest to being clear and understandable for consumers?
Remember, the manufacturer can disclose as many ratings they choose.
I don't know. But in all programming, the dynamics vary, as does the spectral content, over MUCH shorter timeframes than five minutes. That variability can be modeled for specific examples of difficult material--brickwalled pop, movie sound effects, etc. In no case is actual content simulated by rated power being applied across all ten octaves for five minutes, or even at any frequencies at the extremes of those ten octaves for five full minutes.
Even with movie sound effects, it may be loud--0 dB full digital level played at rated power output--for some seconds, but it would not be so at extreme frequencies simply because that content would destroy consumer loudspeakers. We've heard of examples of sustained loud sounds in recordings, but not for more than a few seconds and not at 20 KHz (for example). And if the quietest bits of a brickwalled pop tune are, say, 6 dB down from the loudest peaks--which is very much brickwalled--the power needed for the quiet bits would one quarter what is needed for the loud bits. And, again, there's no way that content would be that loud at 20 KHz even if it is that loud between 50 and 5000 Hz, because it would destroy tweeters that usually have power ratings in the single digits of watts or a bit more.
Creating that model profile of dynamics and spectral content would be a good task for an expert working group convened to develop an appropriate standard for rating power that would actually be relevant to consumer use cases. Again, the acceleration and speed profile of the different fuel economy reporting requirements for cars provides an example of linking product performance estimates with realistic and typical use cases.
Yes, manufacturers can report different power levels. But the level required by law (whether or not that law is enforceable in practice) to be most prominently displayed should be most closely traced from realistic consumer use cases, because the point of an FTC rule is to provide market clarity for consumers poorly educated enough to need the FTC's help. People like us don't need the FTC.
Again, if you want a durability or heat-management standard, construct an appropriate standard. I would not oppose an indefinitely continuous test that demonstrated that at rated peak power output, those standardized profiles of dynamics and spectral content did not cause the active elements of the amplifier to exceed the temperature ratings of those elements. "Indefinite" could probably be defined as long enough for those temperatures to stabilize playing that content.
And also again, experts who are going to be more demanding won't need the FTC. Equipment intended for demanding applications that exceed what typical consumers would do would be specified more fully for that demanding customer base in any case, as live sound equipment is more fully specified than consumer equipment.
Rick "has said all this before, several times" Denney
