So you are deceptive and dishonest when you exceed the speed limit with your car?Deliberately choosing not to follow regulations is deceptive.
And you know that how? You consulted the FTC and they said mere simulation is good enough?That interpretation is incorrect.
That's not quite the same thing. My choice of words might not be semantically accurate.So you are deceptive and dishonest when you exceed the speed limit with your car?
It is evident from the way it is written.And you know that how?
A regulation must be enforced and strongly for it to have any impact on the market. No company wants to volunteer to either derate their power, or increase cost/retail price when the rest of their competitors are not. Their business will sink while their competitors smile all the way to the bank. A wise business decision would call for ignoring the regulation until someone comes knocking on your door.Therefore, opting not to comply with the FTC regulations that they are legally required to follow would be considered deceptive, rather than dishonest.
I understand that they may not want to, but they actually must comply if they intend to follow the law.A regulation must be enforced and strongly for it to have any impact on the market. No company wants to volunteer to either derate their power, or increase cost/retail price when the rest of their competitors are not. Their business will sink while their competitors smile all the way to the bank. A wise business decision would call for ignoring the regulation until someone comes knocking on your door.
I don't see how the section title suggests any implications; the text that follows is what truly matters.The rule is below (as was provided earlier by @EJ3 and probably others before; this is from the copy of the Federal Register that one of the FTC authors sent me last year -- I don't have the full thing downloaded, just the update in the Federal Register).
"Shall be obtainable" means products must be able to attain their rated power for five minutes and achieve no more than 1% THD+N measured at the end of those five minutes for all frequencies from 20 Hz to 20 kHz. There is nothing I see about what testing is required to verify compliance. The title of the section is "Standard test conditions" which implies this is something they must test.
Is it? I don't think that's accurate.A legal interpretation of "shall be obtainable" is that manufacturers must test "everything" to meet the spec,
This is a really weird hill you're dying on here. How exactly can a manufacturer claim they meet the specified parameters without some sort of testing regime? The notion that they can verify compliance with some "simulations" or whatever is absolutely silly and you know it. Manufacturers complying in that way would make the regulation worse than meaningless. Even with testing, there has to be a standard testing regime for every manufacturer to follow. If there's really multiple valid ways to interpret and test for compliance, then the resulting numbers would not be comparable with one another and the regulation is meaningless.The phrase suggests that something should be accessible or available, but it does not define the methods by which that accessibility is attained.
I addressed that specific point in post no. 1660 in response to Amir.This is a really weird hill you're dying on here. How exactly can a manufacturer claim they meet the specified parameters without some sort of testing regime? The notion that they can verify compliance with some "simulations" or whatever is absolutely silly and you know it. Manufacturers complying in that way would make the regulation worse than meaningless. Even with testing, there has to be a standard testing regime for every manufacturer to follow. If there's really multiple valid ways to interpret and test for compliance, then the resulting numbers would not be comparable with one another and the regulation is meaningless.
Are referring to for example let's say the likes of Sony which to my understanding via computer can design, layout and then start the assembly machines without prototyping. Then using the design parameters to state whether compliance is in effect or not?I addressed that specific point in post no. 1660 in response to Amir.
Yes, that’s an example.Are referring to for example let's say the likes of Sony which to my understanding via computer can design, layout and then start the assembly machines without prototyping. Then using the design parameters to state whether compliance is in effect or not?
From a defense department or space program perspective, the rule probably seems reasonable, because those transmitters and amplifiers will be sending indefinitely continuous data streams that are fairly constant in signal level, and because the consequences of failure are extreme....
In my work/world, "continuous" means "for the life of the product". Since I have worked on circuits for things like space applications and mission-critical components for the medical and military fields, if something was rated for continuous operation, it had to pass stringent design reviews and testing to prove it could handle that. Low-level circuits rarely had issues passing lifetime tests. For high-power RF amplifiers, not something I designed, it was common to have a maximum continuous ("unlimited" time of operation) power rating, and a peak rating with defined peak (pulse) power and duration specified -- including a "cool-down" period between max power peaks. Things like commercial/military radar systems and medical scanners typically had such ratings. Early ultrasound scanners had some serious heat problems, for example, when the handheld scanner got hot on a lady's tummy.
I don’t see anyone suggesting that a single FTC value should replace all the others.From a defense department or space program perspective, the rule probably seems reasonable, because those transmitters and amplifiers will be sending indefinitely continuous data streams that are fairly constant in signal level, and because the consequences of failure are extreme.
But let's consider something more realistic in high-power RF amplifiers: Amateur radio. Amateur radio amplifiers are routinely rated for intermittent output. The terms is ICAS--Intermittent Commercial and Amateur Service. For transmitter amplifiers, ICAS is something like a 50% duty cycle, and even that is used for single-sideband modulation. SSB amps are rated for peak envelope power, which answers the question of whether the peaks of my speaking into a microphone will clip the amp. FCC rules for maximum allowable power are also measured as peak envelope power. That power is calculated from the current delivered at the peak voltage in the modulated signal. Of course, in RF sideband operation, the audio signal modulates an RF carrier only on one side of the ground reference. The receivers construct the negative signal. For AM operation, where both positive and negative signals are modulated, the power is derated to 25% of the SSB PEP rating. For RF amplifiers intended for continuous service, such as broadcasting a continuous RTTY data stream or for FM broadcast where the carrier is continuous, the rating structure would be CCS, or Continuous Commercial Service. That's the same rating that would be used for indefinite continuous key-down for CW (i.e., morse code "continuous wave"), but, of course, CW is intermittent in actual use. We use key-down to tune the loading of vacuum tubes for RF transmitters, but we all know not to exceed 6 or 8 seconds if we don't want to see holes magically appearing in the plates on the tubes. Learning how to retune the tube loading after a change in frequency quickly is one of the skills. Amps rated for indefinite continuous key-down are grossly overdesigned for ICAS, and usually have a PEP for sideband signals as much as twice the key-down rating.
Examples of high-end, high-power Acom amplifiers:
* Power Output: 1,500W PEP, 1,200W continuous carrier; for continuous carrier transmissions longer than 15 minutes the external auxiliary fan must be installed
This one costs about 75% more:
* Power Output: 1,500W PEP, 1,500W continuous carrier; for continuous carrier transmissions longer than 15 minutes the external auxiliary fan must be installed
Note that they never report PEP greater than 1500 watts, because that's the maximum legal limit for amateur radio. But the second of these will easily produce 2000-2500 watts PEP for sideband or normal CW in ICAS.
The amp I use is a lower-powered (but still high-quality) Ten-Tec Centaur, rated at 600W PEP ICAS. It's published rating is 600W PEP SSB/CW, 350W RTTY.
Hams that buy amps for sideband operation can get a 1500-watt PEP ICAS amp that will work perfectly for them at the maximum legal power output. If they are CW operators, that amp will also still work fine, because the spaces between the dots and dashes, and the time spend listening to the other party, reduce the duty cycle. If they want an amp for continuous RTTY broadcast or for AM operation at peak envelop power, they'll need to spend more but the ratings that support those use cases are provided.
Point being, for intermittent applications or those that use non-continuous signals, there are standards for rating power output that are appropriate to the application. The issue isn't whether an amp's FTC rating doesn't represent what it can do in the worst scenario (at least for five minutes), the issue is whether that value actually tells uneducated consumers something important about playing music loud. Clipping occurs when an amp can't fill a peak waveform, not whether it can't fill a continuous waveform indefinitely at some much reduced amplitude.
Personally, I think a single number is foolish. Even fuel economy for cars has two ratings plus a "combined" rating that everyone knows is just a model that may or may not apply to the way they drive. But if I had to have a single number, I'd want it to represent peak output when playing worst-case actual program material, and as long as the signal is actual program material (or some reasonable model thereof), it should operate indefinitely without exceeding the rated temperature of the hot bits.
Rick "appreciates Don's perspective but the FTC isn't rating things for guys like him" Denney
I've not seen that happen. Are there examples?Clipping happens during short bursts, but an amp that struggle under continuous load may also struggle with certain peaks, depending on the duration
That was a mistake on my part. You caught me before I had a chance to edit it out.I've not seen that happen. Are there examples?
Well you may be right. If an amplifier has a fully regulated PSU, it may have no peak capacity over the sustained power. I've not seen it, though.That was a mistake on my part. You caught me before I had a chance to edit it out.![]()
I have said that high-power RF amps often include intermittent power ratings with on and off (cool-down) duty cycle periods specified. Very common, and would work with the intent (I think) of the FTC rule: continuous power rating, then add a peak power rating that is adequately defined (e.g. the IHF 20 ms burst test) for headroom. You are reading too much into my post without reviewing prior context. Which is the same problem I have and why I should really just stay out of this mess; I am too lazy to post a book with all relevant experience, and then end up being lectured because my responses are either not clear or insufficiently detailed, about a topic I appreciate but realistically is just a bunch of keyboard warriors (myself included) whining about.From a defense department or space program perspective, the rule probably seems reasonable, because those transmitters and amplifiers will be sending indefinitely continuous data streams that are fairly constant in signal level, and because the consequences of failure are extreme.
No, no. I was just typing faster than my brain was working. That’s what happened there..Well you may be right. If an amplifier has a fully regulated PSU, it may have no peak capacity over the sustained power. I've not seen it, though.
