Power amplifier tests with respect to FTC: 16 CFR Part 432 (July 5, 2024) requirements on output power claims
Yes, when considering the words "shall" and "must" in isolation, that is accurate.
In the context of the phrase "shall be obtainable," it has a different implication: it suggests that the amplifier must be capable of delivering its full power across the entire frequency range. However, it does not explicitly require manufacturers to conduct tests across that range or to provide documentation of such tests. In practice, a manufacturer could potentially avoid testing their amplifier altogether, opting instead to rely on simulations and calculations if they choose. However, if the amplifier is tested by third-party reviewers or the like or selected for examination by the FTC, it must meet the performance claims made by the manufacturer.
That makes sense as a reading. Thanks. I just know that as someone who has briefly looked into very small scale manufacturing of amplifiers I would basically have to do it without specifying power (or give a specification that is misleadingly low about how loud the amp was) given my discomfort with the legal threshold this rule creates.
That's contradictory. A manufacturer can't comply with a regulation demanding that it meet deliver "full power" across a frequency range without testing that shows it can do so. If they could comply by just claiming it does so, the regulation is meaningless. Nevermind the possibility that third-party testing might show that it does not in fact comply would mean opening themselves up to liability.
Don't try to convince i
ndividuals with logic, facts, or even laws, when they have a deep-seated inability to consider anything other than their own sense of infallibility. You are just wasting your time.
So how about this fact. FTC regulations mandates THD+N specification but never says how that is supposed to be measured. As you well know, the measurement bandwidth is critical to proper THD+N measurements. The more the bandwidth, the more noise and distortion is captured in THD+N. And it is not just you and I that insist on knowing the bandwidth, but here is Audio Precision itself: https://www.ap.com/blog/thd-and-thdn-similar-but-not-the-same
When THD+N measurements results are stated or specified, to be meaningful, details such as the stimulus level and frequency (or frequency range), the measurement bandwidth and the DUT gain, should be included. For example:
Correct: THD+N less than 0.01%, 1 Vrms, 20 Hz - 20 kHz, unity gain, 20 kHz BW
Incorrect: THD less than 0.01%
What FTC is doing is the "Incorrect" version. An amplifier that can't pass 20 kHz with wide THD+N bandwidth measurement, can opt the bandwidth to be just 20 kHz and with it, not count any harmonics! And with it, "pass" such a test. Picking the bandwidth number is a hard problem and one that needed to be investigated instead of just throwing it out there as the regulation has.
Apologies. Not sure if this has been covered already, but does anyone know why this wasn't pointed out to the relevant people prior to it's formal approval? Seems rather odd to me.
Or perhaps it was, but was just ignored?
Not sure if this has been covered already but does anyone know why this wasn't pointed out to the relevant people prior to it's formal approval? Seems rather odd to me.
Cause probably the companies failed to meet the ONE instance you're allowed to unlock the vault and let engineers loose out there.
So,marketing people did the work as it seems.
Or not understood. This is why standards are vetted by standards committees filled with technical experts, and one difference that I keep harping on between a standard and a regulation (which keep getting conflated despite being very different animals).
Yes, but surely there should be technical experts involved in both.
There was a period of time for comments, and many of us here as well as elsewhere made comments, but as @SIY said regulations are not necessarily vetted like a technical standard would be. There was a thread here on ASR with some folk commenting who knew the FTC person(s) involved, and they were pretty overwhelmed. My impression was one or two technical types, who may not have had a lot of experience in the amplifier design area, and then the bureaucrats wrote the final rule based on what they think the technical part means. It is pretty clear there was insufficient knowledge and/or attention paid to specifying the rule in a manner consistent with engineering practice and testability.
Standards go through an entirely different process, typically far more technically-oriented, and usually with far more review and vetting (though it doesn't prevent poorly-worded standards from being implemented). Standards are often driven by industry and technical folk, versus regulations driven by governments, politicians, and lawyers. I have been involved with a number of standards during and after development but few if any regulations except when they fell out of the standards.
Hate to say it but this just reinforces my suspicion that the competence of the politicians and bureaucrats making these decisions has declined somewhat over the years (coincidentally, as I get older and more cynical.)
Apologies if seeming a tad political, will but out now!
I've been in some technical standards groups and they are not the sort of environment where policy makers and lawyers hang out. It can be grinding work. If there is a dominant manufacturer they tend to dominate (and it can be tough gainsaying them if they are wrong). If there are several dominant manufacturers, it can be a bit of a carve up. Sometimes manufacturers develop pre-standard equipment and it's in their interest to get the standard to look as close as possible to their implementation (so changes don't require new silicon or boards). Despite all the hard work, it's often common for something that seemed obvious in the planning phase is completely misinterpreted in the field; simply due to poor wording.
Back in post #394 I said:
The actual reality is that every "standard" test published is flawed:
  • Not connected to real-world use
  • Too narrow in scope
  • Based on description, not mathematical notation
  • Lacking in empirical evidence for the approach adopted
This gradually gets fixed through real-world tests, application and refinement once real results are collated. FTC: 16 CFR Part 432 (July 5, 2024) is not there yet.
I agree with most of that, but the Standards with which I have been involved were very connected to the real world, often had very rigorous math and such as well as (reasonably) well-defined practical test procedures, and included empirical data as part of setting the standard. But they may have been outliers; IEEE ADC and DAC Standards, OFC, PCIe, and SAS were the ones I have worked with the most and most recently. I do agree major manufacturers often drive industry standards, hard to avoid for a lot of reasons, good and bad. There were some that were pretty loose, though not as bad as this current FTC rule, but standards driven by industry in my experience (albeit limited compared to the world at large) were much better defined and clearer than the regulations applying to the same products. Some standards are loose, HDMI being a prime example of an interop mess, and some regs are very tight for things like laser emission and some electrical codes, but IME most standards are much better defined than most regulations.
But yeah, something perfectly clear to the author, standard or reg, can sometimes be interpreted completely differently in the field... And some of the standard tests were driven by test equipment manufacturers, leading to different results from different test equipment (Keysight vs. Tek being a painful example I lived through; not only did they disagree on some test details, but tended to specify bandwidth, resolution, and such tightly tied to their latest DSOs or BERTs, for example, potentially locking the other vendor out of the test labs).
I do not think anybody is disagreeing that the FTC rule is poorly defined.
I personally ignored it. The headline at the time was FTC abandoning the regulation. Since I knew they had no enforcement resources, I didn't care either way. I was surprised to see that it not only got revived but changed the original requirement into something impractical. I would have never thought that the government would make ad-hoc changes like this, simply through comments sent in by random folks/entities.
As a general rule in the industry, having government action is the last resort as it is 99% political and subject to such screw ups. We always wanted to solve the problem ourselves than leave it to chance this way. For this, I blame the industry and its associations.
I find it interesting that blame is being raised about the industry and its associations now. You also had the opportunity to send in comments and share your perspective. Wouldn’t you also be considered part of that industry and its associations?
It's always easier to reflect on issues after the fact rather than addressing them in the moment.
I'm not saying manufacturers shouldn't test, but they could technically avoid it if they chose to. As long as their engineering and simulations are reliable enough to determine an FTC-rated power output, they can still comply with the regulation without direct testing.
The regulation doesn’t explicitly require testing, only that the amplifier meets the requirements in it. There are multiple ways to achieve compliance. Ultimately, it’s up to the manufacturer, and if they choose to be dishonest, as you mentioned, that’s their decision. However, with the FTC regulation in place, dishonesty now carries risks -such as warnings, fines, and even import bans.
As you can see, this doesn’t make the regulation meaningless in any way, nor is there any contradiction in it.
Industry and trade organization members have companies that pay their salaries. Such regulations determine their success in the marketplace. I qualify as neither. My future doesn't depend on what FTC does or doesn't do.
It is but in this case, I am bringing significant experience from when I was in the industry and drove many associations, standards, patent pools, licensing and regulations. We didn't drink water under my watch without managing this aspect of the business. It is on that basis that I say organizations such as CEA/CTA were sleep at the helm. As were major consumer electronics companies. This is partially excused because they like me, know that the FTC is a paper tiger when it comes to such regulations. But some blame must be accepted on their front.
Ultimately, I have paid my dues so please cut out the debating tactics to put this fiasco at my feet. My job now is to provide corrective action which involves increasing awareness of why this is not a workable regulation. And not jump when the few of you scream about putting it to use anyway.
If there are multiple ways, then the results cannot be compared to each other, defeating the very goal of the regulation.
Nothing about them ignoring FTC regulation makes them dishonest. They simply don't care about a regulation that is a) completely broken and b) won't be enforced anyway. That is what I would do if I were in their shoes. There are countless companies I suspect that don't even know about this ruling let alone want or not want to do anything about it!
No company with inside or outside attorney advising them would let them do what you say. Please don't make up nonsense like this. Simulations? Give me a break....
In the same comment, you're referencing authority while also stating that you're not part of the industry. If you believe you could have provided the FTC with valuable insights, perhaps you should have. "With great power comes great responsibility" -Uncle Ben ;) .
I’d also appreciate it if you didn’t label my comments as a tactic -I’m simply sharing my thoughts and opinions, just as you are.
No, that’s incorrect and a significant misrepresentation of my words.
If a manufacturer has engineering and simulation models refined to the point where their published FTC rating reliably holds up in real testing, why would they need to conduct extensive physical tests?
The FTC regulation still establishes the requirements and testing protocol that amplifiers must meet, ensuring a direct and standardized basis for comparison.
Deliberately choosing not to follow regulations is deceptive.
I was simply addressing those, like you, who interpret the text as requiring testing at all frequencies between 20 Hz and 20 kHz.
That interpretation is incorrect.
I’m explaining that, if they choose to, manufacturers are not actually required by the regulation to conduct any testing at all.
