olieb
- Joined
- Jul 1, 2023
- Messages
- 549
- Likes
- 960
You are kind of funny.Let's not turn this into political ddebate.
Complaining about others, when you started this and you continue it.
But back to topic.
From the FTC rule
"shall be obtainable" - how can this be tested at all?Any power level from 250 mW to the rated power shall be obtainable at all frequencies within the rated power band of 20 Hz to 20 kHz without exceeding 1.0% of total harmonic distortion plus noise (THD+N) at an impedance of 8 ohms after input signals at said frequencies have been continuously applied at full rated power for not less than five (5) minutes at the amplifier's auxiliary input, or if not provided, at the phono input. https://www.ecfr.gov/current/title-16/chapter-I/subchapter-D/part-432
The way I read it, to test for a frequency you are supposed to apply full rated power for 5 min at a certain frequency and then test for THD+N at that frequency (at different power levels).
"All frequencies" sounds quite a lot. And so does "any power level". I am surprised they did not say "at all impedances between 3Ω and 8Ω", too.
Seems like an unpractical amount of testing. Maybe the FTC should think about giving a more precise testing procedure, that can actually be done. I am sure the experts there know how to do it.
But even then giving "rated power" as the minimum of power at all measured frequencies (including 20kHz) does not makes much sense for music, but hey, what do I know.
Where am I wrong?
