ThatSoundsGood
- Joined
- Aug 12, 2022
- Messages
- 420
- Likes
- 436
Well, I like to capture my amplifiers because those captures sound much better than any of the stock amps in the quad cortex. But I have not had any luck with capturing cabinets and I think that is because of the mismatch in output impedance between a regular amplifier and a guitar amplifier. My cabinet captures have all been done with a high quality Class D amp, but they all sound really flat and have too much low end. So, I use my amp captures and the cabinets that are already in the quad cortex.I’m using a Fractal Axe FX3. I’m just capturing an IR of the speaker and letting the Fractal handle the amp. Fractal has modeling for the effect of the speaker impedance curve on the power amp, as well as distortion and compression of the speakers.
@KSTR it sounds like you are doing a more comprehensive process of capturing the whole amp, not just the speaker.
I think the key here is that you need an amplifier that will mimic what a guitar amp does. Maybe you could use a Marshall or similar amp, but with the gain settings really low. It would probably take a bunch of experimenting with getting it right.
Do the stock cabinets in the Fractal not work for you? I have worked with a lot of bands who use Fractals and they will generally capture their amplifier but use the stock cabinets.
