My experience: Currently using LaScala II with a (probably 10-12 watt ch) push pull 6v6GT/6SL7 China integrated unit. Mostly because it looks cool. Chrome chassis, lucite tube guard, lacquered side panels, and all that. Sound is loud enough with the volume knob at about 10 AM. Sometimes 11. FWIW, using power tubes from a Marshall guitar amp, but they sure look like rebranded black glass Shuguangs.
I've also driven them with my home built Dynakit EL-34 mono amps, and home built pre, but that combo sounded a bit 'muddy', if you know what I mean. A lot more power, though. When winter arrives I'll try that combo again, because the added heat will be welcome.
Best 'sound' was with AHB-2/DAC3hgc, playing either digits or records via a Project Phono Box, but I've moved those into a secondary system (which I tend to use more, because it's in my den), driving a set of JBL L100 I've had for, I guess, 45 years or so.
Sources used with LaScala are a Garrard Z-100 I rebuilt, along with a new AT 740ML cartridge (2.25g tracking). Also have a sub connected when I play digits. With records I don't notice the lows so much. La Scala rolls off pretty fast around 50Hz, I'd guess. Also a Bellari 'kind of tube' phono preamp (first stage is, I believe, an opamp). It's noisier than most might like, but I don't notice it from my listening position, and really don't care anyway. Features a low filter you can switch on or off reducing some record player noise, so it's got that going for it. And has some kind of headphone amp I never use.
Klipschorns are a bit more sensitive than LaScala, and go a bit lower, I think. Today the price of either model is through the roof, but have you gone to the grocery store lately? It's just the way things are. Even higher end signature Chinese sourced Epiphone electric guitars are pushing $1,500.00, these days. Unbelievable! Shecter Guitar Research is the best overall deal, probably--Korea or Indonesia. Ground hamburger from I have no way of knowing where is still affordable. Top Cow filets are pretty much out of the question. But I digress.
In any case, 100 watts is more than you'll ever need, if you want your to keep your inner ears. 10 will likely be adequate for most average sized living rooms.
