Here is my initial ART measurement - 5.1.4, with 4 full range speakers and 1 sub - using Dirac Default support groups and levels:
Same system, with the addition of a 2nd sub (same as 1st) but with the support groups adjusted/tweaked - and heights removed from any support duties
from 40 Hz up I have 4 base layer speakers as well as 2 subs working - and the results are exemplary.
I have two base layer speakers that cease support at 40Hz, and the rest of the speakers are theoretically capable of 24Hz - but the messiness in the decay between 35Hz and 20Hz tells me that I am probably asking too much of them, and driving them into their distortion zone, where their ability to contribute to ART becomes limited by the THD... more experimentation to come... however - this is now showing a very very good result in my room, and my subjective results are that my system is sounding better than it ever has before - and definitely is NOT lacking in bass.
Objectively - there is no lack of bass.
Subjectively - all the decay has been removed from the room - demonstrably so in the above graphs! - and we hear the removal of bass energy.
Having said that, the energy that was removed is a form of distortion, and was obfuscating the detail of the sound.
So you can compensate by increasing the SPL's of the primary signal (which may require speaker/sub update/replacement) - or you can opt to accept that your preference is to have some distortion present as you find it euphonic.... which may result in such people opting for DLBC over DLART, much like many choose valves over transistor amps in a search for euphonic distortion.
The other thing to note - ART's bass management means that any/all bass capable speakers - including full range mains - will contribute - whereas DLBC cuts full rangers off at the knees - and only uses sub's for bass. (sacrificing a variable amount of bass in the process...).
It will be interesting to see whether ART configurations with lower support levels can be used to provide a "wet" configuration (ie: with remaining decay energy) as opposed to the Dirac default of a "dry" configuration - examplified by my current setup, and which I am very happy with!
