Possible solution for DTS/Dolby/Atmos+eARC+HDCP to AES/EBU - via Dante? (for Okto DAC8PRO etc)
His Measurmentsystem can clearly show the right Jitter Values with special Jittermeasuring, i can only measure THD+N also my Scope didn't has integrated Jitter measuring Rutine can only measure jitter oldscool ;)
May be there is another reason for my Measuring on SU-2 with Jitter feeding in to it but why all other devices like MOTU could reduce it easely by his own???
I have some more DAC's here flying around will make an Test with them too! Let see how they reduce incomming Jitter!
Cambridge Audio DAC Magic
Pioneer U 05
Music Fidelity V90-DAC
Terraatec DMX 6FIRE USB
ZOOM U-44
One thing i can say and thats by sure 950ps Jitter comming from HDMI Extractor (Picture shows SPDIF Out):
mclk on HDMI to I2S Board:
I had 2 different HDMI to I2S Boards and last picture shows mclk of the better one Diveation around 586ps!
Maybe the SU-2 just depends on the DAC chip itself for jitter reduction.
I know that some other DACs do have additional upstream jitter reduction methods, like PLL and ASRC.
So as it happens I was about to suggest using a different DAC to see if that made any difference.
It's worth having a look at the other DAC and preamp tests in SoundStageNetwork. I think the RME was the only one to pass the 500ns jitter test.
Than this is only Marketing and does nothing ?:
500ns is a lot, i have only to remove 1ns around.
My Blueray player gives only 250ps on SPDIF, thats more common i guess.
Talking about jitter more generally, RME seemed to target MADI because that has around 80ns jitter, and they wanted to get that below 1ns.
SteadyClock seems to have achieved that. Similarly, SteadyClock FS seems to have succeeded in getting it below 1ps.
Other manufacturers pay a lot of attention to jitter, but it's often word salad like "64 bit acoustically focussed clocking" (Antelope Audio).
Lynx Studio are more specific. Their AES16e is a 16 channel PCIe card that competes with the RME HDSPe AES:
Includes Lynx-exclusive SynchroLock™ sample clock generator for 3000:1 jitter rejection on external clock sources
That equates to 20log3000 = 70 dB jitter reduction, so slightly better than SteadyClock.
The Lynx Aurora(n) and Hilo2 go one better with Synchrolock 2. Very necessary, as Synchrolock was extremely slow at locking to incoming audio.
All new SynchroLock 2™ high-performance sample clock technology provides a whopping 300,000:1 reduction in jitter, 5 second lock time and absolute accuracy. Word clock I/O provides one input and three outputs on BNC connectors.
That equates to 110dB, which is comparable to SteadyClock FS, but it's not available on the Lynx AES16e PCIe card.
I read all the SoundStageNetwork reviews, and none were as good as the RME, though the EMM DV2i and Eversolo DMP-A8 were very good.
Therefore I think RME are the real deal.
May be this artifacts i see on my Measurings comes frome thomething else who knows, but it looks for me that it could be Jitter or Phasenoise related.
And the easy Point is to ask (RME Card, MUTEC not involved!!!)
How an MOTU Interface could handle it easey by his own, not showing any artifacts on Analogue Out while connected to my Extractor and The SU-2 DAC can't deal with it at all!
Direct connected with an RG58 Cable 1m SPDIFF and Analoge XLR into COSMOS ADC Stack!
And i tested 2 differen't SU-2 DAC'S, they act the same!
SO keep that Steadyclockstuff away and look only to this 2 Devices how they act this different on <1ns SPDIFF, if it is Jitter Related?!
And on Motu you has USB connection to an PC and an normal small switched PSU to connect into the Mains that could collect Noise everywhere!
SU-2 has an internal switched Powersupply called super low noise ;)
That what i bother about
Here the Crazy Stuf that i can't understand, measured an old Musical Fidality V90 DAC (was also an cheep one at release Time) on my Extractor connected via SPDIF:
For comparence SU-2 again (Same digital Cable used, V90 has only RCA so other analogue Cable used into Notch):
Isn't it crazy ;)
How this could be???
Same Measurementequipment, same Source, same Extractor!
V90 is RCA Unbalanced (Cable Used RCA to 3,5mm TRS, Tip +, all other to GND )
SU-2 XLR Balanced (Cable used XLR to 3,5mm TRS, +, - and GND)
It looks like the Musical Fidelity has higher noise and distortion, but lower jitter than the SMSL, right?
Did you post any measurements of the MOTU in the DIYA thread? I don't recall seeing any. The MOTU is good.
Yes my understanding is it comes from Jitter, but RME Mastermind says, it could be something different (Measurment with RME Card between Extractor and SU-2 DAC) on RME Card, they look into it ;) But here no RME Card involved!!
I did, here again MOTU SPDIF IN directly from SPDIF OUT on Extractor, clean as Hell, >10dB more noise than SU-2, sure:
Here on my Thread:
https://www.diyaudio.com/community/...ound-digital-aktive-setup.440807/post-8413719
So if it is not from Jitter and it comes from Extractor (PSU nois or what ever) i would understand it if all Devices has the same artifacts on his Measurments!
But no, some Devices are clean and some not. :(
For making it clear i talk about this Artifacts and this wider Triangle (red marked) from 1kHz here:
I've been looking at the RME HDSPe AES. As far as I can tell, there are three versions - all with 16 channels of AES3 input and output:
  1. There was a PCI version, which is presumably obsolete now.
  2. This was updated to PCI Express (PCIe). This is called Rev 1.0.
  3. Rev 2.0 looks to be completely different. I can't find any explanation of the differences. Maybe it drops transformer coupled outputs, and maybe it has SteadyClock FS?
I suppose the SU-2 simply isn't very good at filtering out jitter. I must admit I thought it would be better, but now you know, there are ways of dealing with it.....
View attachment 568949 View attachment 568950 View attachment 568952
I have the right Card (Latest) Rev 2.0 and i would suggest this black small Boxes after Connector are Transformer or Coils, 8 of them for 4 IN + 4 OUT AES.
They have 6 PCB connection so SMD Transformers i would say.
So all connections in and Out are stil isolated!
Yes, i have now my MUTEC MC-4 so no brainer to use still SU-2 ;)
But by sure if i own an ATMOS Surround Processor any day, i will do the same Measurments again ;)
I think you're right.
Maybe I should add "Jitter Reduction" to my idealised architecture.
It could go in either the processing layer (RME or Lynx PCIe card), or a DDC (like the Mutec), or the conversion layer (in a DAC or audio interface).
I've been mildly obsessed with jitter for 20 years, and heard folks saying it's a solved problem all that time. Things like this don't help - supposedly scientific research suggesting that 250ns of jitter is inaudible. Years ago, I used to compile the Jitter List , based on measurements published in HiFiNews & Record Review by Paul Miller :
Systems using an SPDIF connection from player to processor typically have a few 100ns jitter, and a few 1000ns with HDMI. The gap has narrowed, but HDMI is still the worst interface. SPDIF and AES/EBU are better, but I-link and async USB are clearly better, so I think the bar needs to be set quite high. I know some disagree, but I don't care.
I thought I could build my own no-compromise system using any good, modern DAC. But then Frunse's measurements showed that some DACs are capable of reducing jitter, while others are only capable of not making it any worse, and I don't know which.
I want to make a silk purse out of a pig's ear - I want great sound quality from any HDMI source. Maybe I need a digital to digital convertor (DDC) or re-clocker to do that, but I don't know much about them. Amir has tested the Singxer SU-1 and Matrix Audio X-spdif-2, but the results didn't conclusively show they improved audio performance. I looked at all the reviews and manufacturers websites and spec sheets that I could find, but there was very little information available anywhere that quantified jitter level and jitter attentuation, apart from what RME and Lynx Studio claimed. I found Audiophonics quoted SPDIF reclocking jitter = 20ps RMS for their DIGIRESCUE DDC, and that was about it.
GoldenSound tested many DDC's, and he went a bit deeper. Instead of showing FFTs with jitter distortion amplitude vs frequency, he published jitter time vs frequency. I found ten of his tests and compiled the results with links. The better performing units had similar results, suggesting measuring equipment limitation (like DAC tests). The MUTEC MC3 was in the midfield, and I guess the MC4 is similar. The Chord M-Scaler was surprisingly the worst, echoing Amir's results, though the raison d'etre of that unit is the brick wall reconstruction filtering.
Jitter, ps44.1k rms44.1k Peak48k rms48k Peak
Holo Red72.9212.974.6217.8
Singxer SU-679.4229.874.8224.8
Audio-GD DI-20HA85.4243.278.7229.2
Denafrips Giai85.9242.684.8263.3
Singxer SU-286.5251.684.8247.1
MUTEC MC3134.1401.8115.7351.0
Singxer SU-1158.4429.6154.5423.7
IFI Zen Stream194.3569.4173.4544.7
Gustard U18499.11,217.0452.71,133.0
Chord M-Scaler778.22,219.0690.41,970.0
It's interesting to compare the charts side-by-side for the MUTEC and the best unit, the Holo Red:
Both plots are close to 1ps at 1kHz, which seems like very good performance. The MUTEC has more high frequency spuria, but they're largely over 20kHz, so probably not an audible issue. It does look like the MUTEC is the real deal, and the MC4 does have 8 channels rather than just 2. If a DDC can get jitter down to those sorts of levels - similar to what you might get from an HDMI extractor - I think good DACs are probably capable of giving good results.
That's a big data-dump, but I did find one other interesting piece. GoldenSound tested the Benchmark DAC3B, which has effective ASRC jitter reduction. It didn't eliminate all jitter when he injected 25ns / 2kHz jitter on a 12kHz tone - the FFT side tones were down at -145dB. John Siau at Benchmark added some comments with some useful numbers:
Jitter immunity can be measured in terms of jitter attenuation. In the review, 25 ns of jitter was applied while playing a 10 kHz (sic) test tone. If there was no jitter attenuation, 25 ns would produce a pair of sidebands that would each measure about -58 dB relative to the test tone. In the test of the DAC3, the resulting sidebands measured about -145 dB relative to the test tone. This is equivalent to 1.4 ps jitter at the sampling clock. In other words, 25 ns is attenuated to just 1.4 ps. This is a ratio of 17,857:1 or 85 dB. Notice that we get about the same answer if we measure the relative difference of the sidebands. The difference between -145 dB and – 58 dB is 87 dB. So we can see that the jitter attenuation at 10 kHz is somewhere between 85 and 87 dB. This jitter attenuation is outstanding, but more importantly, it means that the jitter-induced sidebands are well below 0 dB SPL in any playback system (unless your playback system is producing an SPL exceeding 145 dB SPL).
There's not much good information like this around. It looks like Benchmark Ultralock is somewhat better than RME SteadyClock and Lynx Synchrolock, but not as good as SteadyClock FS or Synchrolock 2. However all three systems seem to really deliver.
If I want to find how other DACs perform, I might have to do what Frunse did and buy the test equipment, and test my system myself.
The Mutec spurs goes up to 52pS at 85kHz and rest are below 10ps thats pretty good.
I have to deal with around 250ps on SPDIF and 950ps on HDMI after Extractor, Same Cambridge Audio Bluerayplayer ;)
And if i look at youre first List 950ps for HDMI seems not the worst Value possible :(
I hope the new comming Surroundprocessors from NuprimeX or Hyperion have beter Value's on his AES Out's
I thought you said you had 10ns from the HDMI extractor?
Connected the MC-4 to the Extractor AES Out:
Jitter from Extractor Spdif Out for comparence Timebase at 10ns!:
I hope so too, but I'm not sure how we would find out.
On Picture, the Scope Timebase was at 10ns ;)
Bluerayplayer SPDIF Out (around 250pS)
Here an Picture, mclk from HDMI Board:
My Problem on Scope is the Periodic Deviation shown on the right (marked red is around 586ps).
But if i look on the Picture on the falling Edge i read 2ns (Timebase at 20ns)
Probably the Deviation is calculated at Triggerpoint on raising Edge, the Line looks thinner there and thats normal.
Also you don't know how Stable the Clocksource on hat Osciloscope is, Jitter vise.
For comparence may be ok, but for absolute Values, i don't know ;)
But i can't spend 50000$ for an Audioprecision AP555 Measuring Device only to test Jitter. ;)
Scopes with Jiter measuring function cost also more than 5000€, Rigol what i read 8000€
https://www.batronix.com/versand/os...eSCQY0p7nfxg4VGudmCuO3K4eQzMlx4kaApajEALw_wcB
I'm a bit confused by some of these digital to digital converters DDCs. Some of them do sample rate conversion, or have a network audio adapter NAA, which is fair enough. However, the primary function of a DDC is often USB to spdif conversion, and what DAC doesn't have a USB input these days? Apart from the SU-2 of course. DDCs generally claims good jitter reduction, and without putting any numbers to it, here are the key elements of what the Singxer SU-6 does in this respect:
Built-in CPLD pre-shaping technology, based on FPGA source synchronization technology,
Newly designed FPGA algorithm, with built-in FIFO buffering data before output.
Innovative single clock system, with all circuits using synchronous clock design.
CRYSTEK's CCHD-957 high-performance femtosecond crystal oscillator,
The USB clock is synthesized from femtosecond clocks using PLL synthesis.
However, I don't know why DACs can't do all those jitter-reduction techniques themselves, instead of having to rely on a DDC. This what the Singxer SDA-6 DAC does:
Large FPGA for digital audio signal processing, self-developed second-generation algorithms,
Independently developed adaptive clock system technology, with four independent ultra-low jitter audio crystal oscillators.
High-performance analog-digital phase locked loop with excellent clock synchronization recovery technology,
The high-end version uses the (Chrystek) CCHD-957
The USB section is equipped with a femtosecond-level local clock system.
When you cut through the usual marketing BS, it seems to me they both have similar jitter reduction processes. So why can't a DAC do it all?
Sometimes Companys need to pay for Licenses (FPGA Jitter reduction algorythm may be Patented) I am not sure.
